March 28, 2024, 08:58:12 AM *
Pages: 1 ... 8 9 [10] 11 12 ... 15
Author Topic: look at what i have been given  (Read 51259 times)
« Reply #135 on: January 30, 2018, 06:17:40 PM »
Have you got the front wheel Merv?
Living on a wing and a weld
« Reply #136 on: January 30, 2018, 06:24:13 PM »
I have now Paul, where did you get that picture of that trike and is there a better shot of it.
« Reply #137 on: January 30, 2018, 07:47:47 PM »
The point about taking the engine out is important - I didn't and regretted it - you really need to use the swingarm pivot to ensure the machine is plum. I ended up cutting, portapowering and rewelding my frame.
« Reply #138 on: January 30, 2018, 08:18:51 PM »
Patriot Bikes in Wakefield. They have pics on facebook.
Before I started on mine I spoke to them. They were talking about 1500 quid to convert the swingarm.
« Last Edit: January 30, 2018, 08:30:49 PM by paulywombats » Logged
« Reply #139 on: January 30, 2018, 08:46:40 PM »
Found this as well
« Reply #140 on: January 30, 2018, 08:48:24 PM »
And again
« Reply #141 on: January 30, 2018, 10:20:49 PM »
Thanks Paul
« Reply #142 on: February 05, 2018, 03:08:09 PM »
Merv, what size tyres have you got on those 15" rims?
« Reply #143 on: February 05, 2018, 06:31:46 PM »
I cant remember paul, i have um all wrap up at the moment, i think they are 205x55x15
« Reply #144 on: February 22, 2018, 09:01:53 PM »
Hey Merv
Where are you up to with your build? Any progress?
I'm fitting mudguards at the moment.
« Reply #145 on: February 26, 2018, 09:21:46 PM »
Have you got the swing arm for the axle yet
« Reply #146 on: February 27, 2018, 03:17:33 PM »
Not yet Terry, i'm turning her into a naked, because of that decision i'm sorting the electrics out because a lot of them are hidden behind the plastics and front fairing especially the relays, there seems to be rather a lot of them. I have replaced the right side handlebar switch from the police one that was fitted to a standard ST one, that got rid of rather a lot of wires. Now i'm trying to work out if i can get rid of the lean angle sensor and the relay that goes with it, if i can that would get rid of a bit more.
« Reply #147 on: February 27, 2018, 03:39:50 PM »
Is the angle sensor a 3 wire green plug type.
« Reply #148 on: February 27, 2018, 06:55:54 PM »
no its not, the lean angle sensor is next door to the lean angle sensor relay
The sensor is connected to the relay by a red wire
The sensor is connected to the relay by a black wire
from the sensor i have a green wire going to earth
from the relay i have a black wire going to a 10A fuse in the fuse box for the ignition, starter and alternator
from the relay i have a brown with yellow chase going to the starter switch,
Does any of this makes sense to you ?
« Reply #149 on: February 27, 2018, 07:19:54 PM »
No
