April 26, 2024, 11:43:59 AM *
Pages: 1 2 [3] 4 5 ... 15
Author Topic: look at what i have been given  (Read 51667 times)
paulywombats
« Reply #30 on: December 01, 2017, 05:55:03 AM »
Will take pics Today and post over the weekend.
Living on a wing and a weld
« Reply #31 on: December 01, 2017, 07:23:53 AM »
The ST you mentioned on ebay  has a Ford diff. Probably Sierra.
« Last Edit: December 01, 2017, 07:26:51 AM by Olds » Logged
« Reply #32 on: December 01, 2017, 10:00:58 AM »
Merv you have all the main component's to build a trike that will save you a lot of cash
You got the bike, axle the wheels Back. drive & prop shaft. it not to hard to join them together
From what i can see is you will need some box section or tube. mudguards/ lights/ front wheel.
« Reply #33 on: December 01, 2017, 05:32:30 PM »
I need to replace the fork tubes as they are badly pitted and rusty. The ones on ebay don't look that good for the money, could i replace the tubes with other makes if they are the same diameter ?
« Reply #34 on: December 01, 2017, 05:57:23 PM »
Stay with the same make. you really need to decide on the back end first
« Reply #35 on: December 01, 2017, 06:49:33 PM »
If you want to finish it soon go the solid axle swingarm route - an irs is a lot of work (although arguably a better solution ultimately). And yes, reliant axle would be my choice too, but I would recentre the hubs to 100mm to suite most modern wheels.
stumpy
« Reply #36 on: December 02, 2017, 09:24:02 PM »
got a couple of piggy B stamps merv!
If it is the abs model pan you have forks are 43mm standard 41mm ... triumph trophy forks are 43 and much cheaper
« Reply #37 on: December 03, 2017, 10:37:38 AM »
i believe mine is the non abs, thanks for the offer of the axle stumpy, i dont know what it is but i'm picking an axle up tonight for 60 quid.
Are the chrome legs of the forks interchangeable between makes and models ?
« Reply #38 on: December 03, 2017, 12:33:27 PM »
GL1500 have 41mm fork tubes but I would stick with the st ones as the wheel and callipers will be the same setup
I thought you already had an axle Merv the wife court you with parts of one in the oven and freezer Cheesy
« Reply #39 on: December 03, 2017, 04:26:07 PM »
I do have one Terry, but as i have collected most of the bits to build a trike i need that one for that set up. Now the bike has come a long i need one for the bike. I did have ago at talking the wife into letting me keep it as a bike but she remembers my younger days on one and said NO.
I was asking about the fork tubes being interchangeable because i want to keep the lower legs for the very reason  you said Terry, that the wheel and brake callipers will be the same setup.
paulywombats
« Reply #40 on: December 03, 2017, 04:47:11 PM »
Pics Merv
paulywombats
« Reply #41 on: December 03, 2017, 04:49:52 PM »
again
paulywombats
« Reply #42 on: December 03, 2017, 04:55:04 PM »
Another angle
« Reply #43 on: December 03, 2017, 04:58:54 PM »
Thanks  paulywombats
Is it still a single shock set up ?
« Reply #44 on: December 03, 2017, 05:11:17 PM »
No you can't just use 41mm tubes from something else Merv. In fact you have to be a bit careful to get he right 41mm tubes for your particular bike depending on year. There are different lengths and I think internal diameters and early ABS bikes also had 41mm tubes
