April 26, 2024, 11:36:50 AM *
Pages: 1 ... 9 10 [11] 12 13 ... 15
Author Topic: look at what i have been given  (Read 51666 times)
« Reply #150 on: February 27, 2018, 07:46:44 PM »
Is the angle sensor a 3 wire green plug type.
no its not, the lean angle sensor is next door to the lean angle sensor relay
The sensor is connected to the relay by a red wire
The sensor is connected to the relay by a black wire
from the sensor i have a green wire going to earth
from the relay i have a black wire going to a 10A fuse in the fuse box for the ignition, starter and alternator
from the relay i have a brown with yellow chase going to the starter switch,
Does any of this makes sense to you ?
No
 Grin Grin Grin
« Reply #151 on: February 27, 2018, 07:55:28 PM »
No
 Grin Grin Grin
Have you looked on a st1100 forum. i think it called a bank angle sensor a saftey device.  if the bike goes over when riding it kills the fuel pump and engine. dont think you can just unplug it.
paulywombats
« Reply #152 on: February 27, 2018, 10:39:13 PM »
I think it may be the engine stop relay and sensor
Living on a wing and a weld
« Reply #153 on: March 12, 2018, 09:31:05 PM »
Would these be suitable for the disc brake conversion
 https://www.ebay.co.uk/itm/2-x-FOR-VW-Golf-MK4-1998-2005-1-4-1-6-1-8T-1-9-TDI-2-0-Rear-Brake-Calipers/282875901090?ssPageName=STRK%3AMEBIDX%3AIT&_trksi
paulywombats
« Reply #154 on: March 13, 2018, 01:38:06 PM »
I think they will fit, they have a 30 days return policy.
« Reply #155 on: March 13, 2018, 05:07:38 PM »
I need help. The engineer i use has gone out of business. I have found another one who thinks he can turn down the hubs but he wants the best part of 100 quid. I could be wrong but i think that's a bit steep. Can any one help.
paulywombats
« Reply #156 on: March 13, 2018, 06:01:17 PM »
Way too much Merv, shop around, must be more engineering places in your neck of the woods.
« Reply #157 on: March 13, 2018, 10:13:17 PM »
What do you want to turn down the hubs for.
paulywombats
« Reply #158 on: March 13, 2018, 11:08:05 PM »
It's either turn down the hub or machine the inside of the disc to get them to fit. If the hub is machined, you can easily replace the discs as required.
I also added this boss as a locator for the wheel, better practice than relying on the wheel studs.
« Last Edit: March 13, 2018, 11:12:07 PM by paulywombats » Logged
« Reply #159 on: March 14, 2018, 05:04:11 AM »
Hi Paul
Did you do your own, if so fancy doing mine, i could have a road trip out to yours  Smiley
paulywombats
« Reply #160 on: March 14, 2018, 02:56:54 PM »
More than capable, just no equipment any more.
« Reply #161 on: March 14, 2018, 05:30:26 PM »
Thats a shame.
« Reply #162 on: April 01, 2018, 08:09:11 AM »
Managed to get to the lathe Merv.
I wanted to machine some parts for a project I'm doing and done these at the same time.
you going to Basingstoke in May. I will pm you later
« Reply #163 on: April 01, 2018, 01:26:52 PM »
The plan is for me to be there, since i started coming i haven't missed one
« Reply #164 on: April 07, 2018, 06:05:54 PM »
No going back now, made a start on the swing arm   Smiley
