December 16, 2025, 07:36:09 PM *
Author Topic: Mx5 IRS info ?  (Read 3727 times)
« on: November 27, 2017, 06:32:01 PM »
Hi peeps,just thought I'd put this up for a fellow monkey..(MERV ) he's collecting parts for a trike build..and maybe using an mx5 Mazda rear axle? And I said if he uses a motorbike engine it's possible the rotation maybe the wrong way ? So any info solutions would be nice?
toad
« Reply #1 on: November 27, 2017, 07:25:45 PM »
I'm pretty certain it will rotate the right way. send Byzmax a pm as he used this st up on a previous build. Wink
« Reply #2 on: November 28, 2017, 08:18:05 AM »
It will also depend on the bike engine. Kawasaki you will have to turn the axle over Honda you don't. not sure on the others
« Reply #3 on: November 28, 2017, 08:43:55 AM »
Should be fine if Merv is still going for a Reliant engine/box. Nice compact, self contained, IRS, that has the advantage of having fully adjustable geometry. Just a shame that the coil over tops mount to the body and not to the subframe. Though I should imagine these would need changing for something slightly lighter and top mounts could be added to the frame.
« Last Edit: November 28, 2017, 11:58:45 AM by Olds » Logged
« Reply #4 on: November 28, 2017, 06:50:23 PM »
He's got a bike he may use ? Maybe a conversion ?
