April 23, 2024, 10:22:29 PM
Wanted
SU HS2 Carb extension
Topic: SU HS2 Carb extension (Read 2264 times)
trikeability
September 26, 2017, 08:15:16 PM »
Need a alloy carb extension so the SU carb HS2 will clear the fuel tank
Anyone fabricate these ?
Building Reliant trike / engine / box and back axle housed in Honda Goldwing K2 frame with Kawasaki Zephyr fuel tank
Thanks
Re: SU HS2 Carb extension
September 28, 2017, 03:35:31 AM »
You can buy h2/hs2 spacer/insulator blocks up to 30mm thick. Would need longer studs. How long does it have to be ?
mrhutch
September 28, 2017, 10:12:00 AM »
notch the tank?
trikeability
September 30, 2017, 03:25:56 PM »
Update
Sourced two half inch alloy SU spacers for HS2 carb so with longer studs might be enough or as suggested notch the tank a little if still need clearance
Thanks for replies
