April 27, 2024, 03:22:39 AM
Trike Tech
fuel outlet pipe too short
Topic: fuel outlet pipe too short (Read 2283 times)
topconker
August 21, 2017, 09:44:42 AM »
Hi Guys, been a long time out but the trike and me lost interest as I still can't sort out the brakes!
Anyway, took the plunge the other day and removed the 2 rear seats cause I didn't fancy fitting seatbelts on them to get it through the MOT.
Then decided to move the fuel tank from under the front seat to the space they have left. Now looking at the tank I see the outlet fuel pipe has been cut off too low to get a decent fit with a clip so wondered if anyone knows of any adhesive I could fix a sleeve over what's left to give me a better fuel line to pipe fix.
TC
The most precious thing you can give your kids is your time.
paulywombats
Re: fuel outlet pipe too short
August 21, 2017, 10:06:59 AM »
Hi
I think you would be better served looking for a better solution than trying to seal a piece on what you have.
If you are unable to get a clip on there it sounds really short.
It's more work, but could you get a new pipe brazed on to existing pipe?
This would be a more permanent fix. Most adhesives don't react well with fuel.
Living on a wing and a weld
Stix
August 21, 2017, 10:09:36 AM »
Devcon is pretty good stuff a two part epoxy with alloy powder in the mix sets up pretty strong and can even be drilled and tapped for low stress situations, so might be a fix for you. Possibly add a bit more pipe using it to give you a bit more length.
Stix
Last Edit: August 21, 2017, 10:11:45 AM by Stix
topconker
August 21, 2017, 10:17:49 AM »
Thanks Stix, I'll take a look at that.
Pauly, that would be the best fix, but the tank is fitted with a blue foam, (I guess to stop the fuel slopping about), so would almost be impossible to braze without blowing myself up.
TC
paulywombats
August 21, 2017, 02:37:36 PM »
Oh we don't want one less Monkey in the World
