March 29, 2024, 12:11:46 AM *
Pages: 1 ... 5 6 [7] 8 9 ... 14
Author Topic: Paulywombats Honda St1100 Conversion  (Read 41747 times)
« Reply #90 on: March 09, 2018, 09:32:33 PM »
new one are easily available through local motorfactors
https://www.trwaftermarket.com/en/catalogue/#market=gb&vehicleType=P&manufacturerId=121&modelId=4737&vehicleId=%7C15416%2CFront+Wheel+Drive+(11%2F00+-%3E+05%2F05%3B+101HP+%2F+74KW)%7C15418%2CFront+Wheel+Drive+(11%2F00+-%3E+05%2F05%3B+130HP+%2F+96KW)&variantId=15416&productGroupId=1009
paulywombats
« Reply #91 on: March 10, 2018, 06:18:15 AM »
Item number on ebay 251650580067
« Last Edit: March 10, 2018, 06:23:08 AM by paulywombats » Logged
Living on a wing and a weld
paulywombats
« Reply #92 on: March 30, 2018, 04:43:11 PM »
Fitted mudguards to trike today, when I came to wiring marker light and rear clusters ( all LED ), the tail & marker light flash when indicators used.
I think it may be something to do with hazard warnings being fitted.
Anyone come across this?
« Reply #93 on: March 30, 2018, 05:57:04 PM »
Are you using a led relay for the indicators and a standard relay for the hazards?
paulywombats
« Reply #94 on: March 30, 2018, 06:12:31 PM »
Terry, I am using standard relay.
How will I use all the original 4 filament bulbs for indicators on the trike plus led's on the mudguards?
Is it with a different relay?
Looking at my wiring diagram I have one relay with 3 terminals.
« Last Edit: March 30, 2018, 06:32:58 PM by paulywombats » Logged
« Reply #95 on: March 30, 2018, 06:35:59 PM »
You may have to change the 4 filament bulbs to leds.
paulywombats
« Reply #96 on: March 30, 2018, 06:40:46 PM »
Just looking on the web, there is a replacement relay for a mixture of filament and led lamps.
« Reply #97 on: March 30, 2018, 06:45:30 PM »
Did you fit a hazard kit. or was it allready fitted.
paulywombats
« Reply #98 on: March 30, 2018, 06:46:20 PM »
Already fitted.
« Reply #99 on: March 30, 2018, 06:48:49 PM »
Already fitted.
The relay may work then.
paulywombats
« Reply #100 on: March 30, 2018, 06:49:49 PM »
Yes worth a try will give them a call on Tuesday.
« Reply #101 on: March 30, 2018, 08:15:57 PM »
I had an electrical problem on the trike and the bloke who was fixing it (me?  It's all smoke and mirrors to me!) said the hazards were wired up wrong, so he wired them up right and I had that very same problem!  Flashing light all over the place.
I thought there was a post on here somewhere about wiring hazards but I can't find it.
paulywombats
« Reply #102 on: March 30, 2018, 09:03:27 PM »
Everything is working fine, but adding the new LED lights to the mudguards has made a bit more work.
One job leads to another. research on the WWW suggests a different relay should cure the issue.
paulywombats
« Reply #103 on: April 02, 2018, 12:04:45 PM »
Well, having a bonus day off today, I work at the National Tram Museum at Critch in Derbyshire.
Closed today due to overnight snow.
Decided to have a look at indicator & hazard relays and check out my wiring.
I've used 7 core trailer cable to run from rear lights on bike to mudguards, via a adaptable box near the rear axle.
Silly me had got my negative colour mixed up. Now all connected the correct way, and no need for new relays or resistors. Result!
Sausage cob ( it's Derbyshire for bread roll ) and a cup of coffee to celebrate, well it is lunch time on a wet bank holiday.
« Last Edit: April 02, 2018, 01:51:23 PM by paulywombats » Logged
« Reply #104 on: April 02, 2018, 03:40:40 PM »
Those mudguards actually look quite good ..I may have to replace mine for the TEST ? Grin
