April 25, 2024, 09:20:09 AM *
Pages: 1 ... 4 5 [6] 7 8 ... 14
Author Topic: Paulywombats Honda St1100 Conversion  (Read 42350 times)
« Reply #75 on: February 05, 2018, 09:21:18 AM »
Hi Terry
Yes please
All done ready for you. do you want it posting or pickup for the monkey meet in May.
« Reply #76 on: February 05, 2018, 09:40:40 AM »
Hi Terry
Yes please
The last three post should be on your thread Merv not on Pauls Huh
paulywombats
« Reply #77 on: February 05, 2018, 12:39:05 PM »
Always happy to accommodate visitors  Grin
Living on a wing and a weld
« Reply #78 on: February 05, 2018, 06:34:12 PM »
Sorry  Grin
I'll give you a pm Terry
« Reply #79 on: March 08, 2018, 10:20:04 AM »
Hi Paul
Have you got any further with the trike, also would you have a link to where you got your rear calipers from also the hand brake cables
paulywombats
« Reply #80 on: March 08, 2018, 05:54:59 PM »
Hi Merv
I have been laid up with a horrible head cold for the last week, so no progress on the trike.
I only have the rear mudguards and wiring to rear lights to complete.
The calipers I have had that long that I can't remember much about them. I had them refurbished. painted and boxed up and put in storage.
I believe they are off a Passat, rather than a golf. The links to handbrake cables and flexible hoses were via ebay, but having checked, they have gone now.
I know, under normal circumstances, Passat cables are a lot more expensive than golfs.
You may be better looking at all golf parts, callipers, brackets, cables. Could be more cost effective for you. I was just lucky at the time I needed cable etc.
« Reply #81 on: March 08, 2018, 05:57:15 PM »
Merv why don't you keep the reliant brake setup/ Huh
« Reply #82 on: March 08, 2018, 06:45:38 PM »
Thanks paul, ill have to see what i can find. Hi Terry, to be honest i just like the look of the disc setup. Going back to my cortina days i never did like working on shoes
« Reply #83 on: March 08, 2018, 10:13:50 PM »
Did you use the original rear master cylinder for brakes Paul. and is it a linked system.
paulywombats
« Reply #84 on: March 08, 2018, 10:27:28 PM »
upgraded to larger master to both rears and kept front as stock.
« Last Edit: March 08, 2018, 10:32:29 PM by paulywombats » Logged
« Reply #85 on: March 09, 2018, 07:37:55 AM »
I did wonder if you upgraded for  vw callipers . on mine I use a merc clutch master cylinder and kept the split brake system 2 rears and 1 front.
paulywombats
« Reply #86 on: March 09, 2018, 12:11:41 PM »
Yes took the advice of the good fellow monkeys on here.
Was advised the original cylinder would be unlikely to serve VW calipers.
Also spoke to a very helpful guy at www.carbuildersolutions.com about rating for replacement cylinder, he suggested 3/4", and works very well.
Good web site and catalogue available (always like pictures), lots of useful tips and hints in there too.
I used the original Honda reservoir and seems to work well.
paulywombats
« Reply #87 on: March 09, 2018, 12:24:33 PM »
Found these on ebay, item number  222788342127, they are from a Passat. Advertised as genuine vw 'fully refurbished' £60 the pair.
« Last Edit: March 09, 2018, 12:28:53 PM by paulywombats » Logged
« Reply #88 on: March 09, 2018, 02:40:46 PM »
Hi Paul,
found them, got them on watch at the moment, what did you do about the carriers
« Last Edit: March 09, 2018, 02:55:36 PM by merv » Logged
paulywombats
« Reply #89 on: March 09, 2018, 08:20:59 PM »
I had carriers with the calipers, one was correct the other the wrong type.
I got a new one of ebay, no longer able to access info that far back.
Think it was from a MK4 golf.
