April 19, 2026, 11:03:00 AM *
Pages: 1 ... 12 13 [14]
Author Topic: Paulywombats Honda St1100 Conversion  (Read 67952 times)
« Reply #195 on: September 25, 2018, 07:46:33 PM »
Sorry paulywombats, but you're a braver man than me - I could trust a new bottom yoke from billet, but welding a cast steel item of unknown metalugical (is that a real word) quallities and hoping it will hold would be a step too far for me. It might be whoever did this has done loads before and tested enough to be sure, in which case all well and good.
All the best.
paulywombats
« Reply #196 on: September 26, 2018, 05:07:25 AM »
Thanks for you comments Mini. You are of course quite correct, so with this in mind I've now added a couple of cable ties. Better to be safe than sorry.
Living on a wing and a weld
« Reply #197 on: September 26, 2018, 05:23:42 AM »
Gaffer tape is the way forward Smiley
paulywombats
« Reply #198 on: September 26, 2018, 05:43:58 AM »
Doh!, I bow to your superiority MM. Damn, why didn't I think to use gaffer tape? I'll get my coat...… (hangs head in shame)
« Reply #199 on: September 26, 2018, 06:29:34 AM »
Doesn't anybody use wire coat hangers anymore ? Roll Eyes
« Reply #200 on: September 26, 2018, 07:46:33 AM »
In these days of plastic, wire ones are getting harder to find and expensive, so tend only to be used on high end vintage lash ups and aerials.
Nicely done Pauly.
My trike has heavy steering as it was designed for raked girders which I didn't like the look of once I'd made them. But as I get older they may get fitted. That or leaf sprung, leading link forks. Undecided
« Last Edit: September 26, 2018, 08:08:00 AM by Olds » Logged
« Reply #201 on: September 26, 2018, 08:57:22 AM »
I must admit the steering on my trike is so light..with a tiny bit of wobble,as yet I've not tried the new wider tyre..still sorting out the front brake..( lack of funding  Grin) but feels like it's gripping when moving around the yard?
paulywombats
« Reply #202 on: October 01, 2018, 05:20:53 AM »
With a few hundred miles now added, I feel the revs are too high. Hopefully the 2.78:1 ratio diff will help.
