April 28, 2024, 10:39:15 AM
Trike Tech
Help please
Topic: Help please (Read 3015 times)
gazzagood
Help please
June 11, 2017, 06:18:46 PM »
The brake light pressure switch has gone on the flapster again and can't remember what thread it was they are golf mrk2 callipers any help would be appreciated Gaz
PLEASE
Re: Help please
June 11, 2017, 08:02:52 PM »
You sure it's 'gone'or does it just need adjusting?
gazzagood
Re: Help please
June 11, 2017, 08:58:00 PM »
No def gone wire snapped just below resin inside switch 😢
Thanks anyway bg
Gaz
PLEASE
gazzagood
Re: Help please
June 12, 2017, 03:18:53 PM »
Can anyone help please 😘😘
PLEASE
Re: Help please
June 12, 2017, 07:46:20 PM »
where is the pressure switch fitted? if it's in a t piece then its most likley m10x1
Re: Help please
June 12, 2017, 07:48:03 PM »
Quote from: scannerzer on June 12, 2017, 07:46:20 PM
Is it connected to a tee piece on the brake pipe from master cylinder to disc brakes?
gazzagood
Re: Help please
Reply #6 on:
June 12, 2017, 10:06:47 PM »
It's fitted to the calliper
PLEASE
Re: Help please
Reply #7 on:
June 13, 2017, 08:01:25 AM »
Quote from: gazzagood on June 12, 2017, 10:06:47 PM
Just checked mine there vw calliper's not sure on model 10x1mm
so yours must be a banjo bolt type
http://www.ebay.co.uk/itm/150946196296?_trksid=p2060353.m1438.l2649&ssPageName=STRK%3AMEBIDX%3AIT
If this is the second time it failed I would consider changing to a in line one and keep it tucked out the way
http://www.ebay.co.uk/itm/4-WAY-BRAKE-PIPE-UNION-BRAKE-LIGHT-SWITCH-TR3-FROM-TS13046-TO-TR4-TO-CT26929-/251695809751?hash=item3a9a3d44d7:g:EgkAAOSw8cNUT81K
gazzagood
Re: Help please
Reply #8 on:
June 13, 2017, 02:05:20 PM »
Thanks
Terry t one on order ''tis banjo type c how this one goes and if packs up again I'll change to other one thanks for the info much appreciated
Gaz
PLEASE
Re: Help please
Reply #9 on:
June 15, 2017, 06:21:50 AM »
I have a similar one fitted to the front master cylinder. It's important to clip the cable to something, as close as possible to the switch (without pulling on it) to prevent the cable from vibrating.
Last Edit: June 15, 2017, 06:26:16 AM by Olds
