April 30, 2026, 10:38:19 AM
General Tech
bit of help required
Pages:
21
22
Topic: bit of help required (Read 166173 times)
Re: bit of help required
Reply #315 on:
August 21, 2020, 09:44:29 AM »
Reply #316 on:
August 21, 2020, 09:13:35 PM »
Ooh, that came out well
Reply #317 on:
August 22, 2020, 08:26:42 AM »
Not so good close up 😢
Reply #318 on:
August 22, 2020, 02:01:46 PM »
I've got a truck like that
Reply #319 on:
August 23, 2020, 04:17:41 AM »
I've got an 'Ed like that
Reply #320 on:
August 24, 2020, 03:11:17 PM »
Reply #321 on:
September 12, 2020, 06:39:20 PM »
I drove it up and down the drive today. I can see the end, its just out of reach. Still no joy with the rev counter, but hey ho, now then where is that list so I can cross off a bit and add a few more things
Reply #322 on:
September 12, 2020, 08:34:39 PM »
I can't remember the last time I drove my project
Did it start & stop O.K?
Reply #323 on:
November 14, 2020, 10:04:25 AM »
Back at it, cycle wing front arches need brackets making, I’m planning. Seen so many arches broken on cars so trying to fine a solution without it becoming a tank
Reply #324 on:
May 11, 2021, 02:26:45 PM »
Update on the red rooster: nothing really, except it starts, goes up and down the drive, stops well. Having something haywire in the alternator, it starts fine, but only shows 11.9 volts, then settles at a nice 13.6. Then for some unknown reason climbs to 15 volts 😱. If I switch off and start again it settles down for a few minutes, then off it goes 15.1 volts. I’ve a suspicion this could get expensive 🤪
fifer
Reply #325 on:
May 12, 2021, 09:44:20 PM »
If your alternator has the following part on the front then it is easily and cheaply fixed .
In most cases you can replace the voltage regulator in situ .
https://www.ebay.co.uk/itm/221222384056?_trkparms=aid%3D1110006%26algo%3DHOMESPLICE.SIM%26ao%3D1%26asc%3D20201210111314%26meid%3Dc91acac2dfc543a29504b610c9326903%26pid%3D101195%26rk%3D2%26rkt%3D12%26mehot%3Dpf%26sd%3D202412832024%26itm%3D221222384056%26pmt%3D1%26noa%3D0%26pg%3D2047675%26algv%3DSimplAMLv9PairwiseUnbiasedWeb&_trksid=p2047675.c101195.m1851
Pages:
21
22
