March 04, 2026, 12:33:47 AM *
Pages: 1 ... 18 19 [20] 21 22
Author Topic: bit of help required  (Read 147326 times)
« Reply #285 on: June 11, 2020, 09:47:51 AM »
and fitted
« Reply #286 on: June 11, 2020, 09:48:22 AM »
« Reply #287 on: June 11, 2020, 09:52:08 AM »
then I hooked it up to my mates central heating flush pump and whoa, amazed at what cra* came away. Pressure tested and left with inhibitor in the system. Phew happy.
« Reply #288 on: June 11, 2020, 03:56:34 PM »
Nice work matey Smiley
« Last Edit: June 13, 2020, 07:48:11 AM by Manky Monkey » Logged
« Reply #289 on: June 11, 2020, 07:09:34 PM »
I was thinking of connecting my power flushing equipment to my trike. I have the heater pack on mine to keep it hot sot the thermostat will stay open
« Reply #290 on: June 12, 2020, 12:26:26 PM »
TerryT. Luckily my mate told me to remove the stat. He did my dolomite sprint engine a few years back, after doing his rover V8. I was shocked what sediment it shifted and hope it helps in keeping the system cool
« Reply #291 on: June 12, 2020, 03:08:30 PM »
Normally I would remove the stat. but on the goldwings you have to remove all the front Tupperware then the two fans and two rads. after ll that you can just see the stat housing. as it is I can remove the bottom panel and connect the pump onto the hose from there
« Reply #292 on: July 15, 2020, 06:56:38 PM »
Back on the "lil red rooster" for a bit. Seeing I have the engine up and running thought I better silence it before those living close get any angrier  Cheesy. Kawasaki 1200 silencer laying around found its way on to the side. Sounds great, not sure about the thin Flexi yet.
« Reply #293 on: July 15, 2020, 06:57:49 PM »
may go for solid pipe and rubber mounts
« Reply #294 on: July 15, 2020, 06:59:14 PM »
Then the bonnet, never been happy with the offsides lump, so took the angry grinder to it and started again
« Reply #295 on: July 15, 2020, 07:00:02 PM »
CAD technology
« Reply #296 on: July 15, 2020, 07:00:57 PM »
1.5 alloy
« Reply #297 on: July 15, 2020, 07:01:45 PM »
more CAD  Grin
« Reply #298 on: July 15, 2020, 07:03:19 PM »
pop rivets, countersunk and spaced 60mm apart, fibreglass taped, not going anywhere
« Reply #299 on: July 15, 2020, 07:04:22 PM »
as far as I have got
