March 04, 2026, 12:37:32 AM *
Pages: 1 ... 17 18 [19] 20 21 22
Author Topic: bit of help required  (Read 147336 times)
« Reply #270 on: May 11, 2020, 04:59:36 PM »
the gubbins, pump and fuel gauge, chopped down in height to fit
« Reply #271 on: May 11, 2020, 05:00:29 PM »
masked up for drilling and tapping
« Reply #272 on: May 11, 2020, 05:01:49 PM »
all drilled and tapped
« Reply #273 on: May 11, 2020, 05:03:06 PM »
then while deburring and cleaning out the swarf it bit me  Sad
« Reply #274 on: May 11, 2020, 06:28:14 PM »
Ouch ! Sheet steel has a nasty habit of doing that.
Is the tank thick enough for the screws to hold and seal with a gasket or will you be bonding the pump/sender to the tank ?
« Reply #275 on: May 12, 2020, 07:31:37 AM »
I’m making a flange for underneath, in two horseshoes, then bolts up through, and nuts and gasket holding the lid down, well, that is today’s plan 🥴
« Reply #276 on: May 20, 2020, 06:27:06 PM »
Bit of history made today, after toiling in the mid day sun, I hooked a battery to the wiring, temporary lead to the fuel pump and Earth, and low and behold it fired up almost instantly 😱. To say I’m chuffed is an understatement. So now I can attach the body work proper. Move forward 👍
« Reply #277 on: May 20, 2020, 06:27:37 PM »
Uhm pictures to big 😢
« Reply #278 on: May 21, 2020, 04:42:50 PM »
600 x 600 Steve.
Send 'em to me.
« Reply #279 on: June 11, 2020, 09:32:50 AM »
3 years on, and it has today driven under its own power. only a trip out of the cave onto the drive way but it felt good to finally get some movement. Still a whack to do
« Reply #280 on: June 11, 2020, 09:40:57 AM »
pipe work and radiator mods to convert to a sealed system
« Reply #281 on: June 11, 2020, 09:42:09 AM »
« Reply #282 on: June 11, 2020, 09:43:07 AM »
« Reply #283 on: June 11, 2020, 09:44:26 AM »
top came off easily and clean
« Reply #284 on: June 11, 2020, 09:45:34 AM »
found a pipe blank that fitted very nice for now
