March 29, 2024, 10:13:46 AM
Wanted
'A' Axle Pinion Cover
Topic: 'A' Axle Pinion Cover (Read 2061 times)
paulywombats
June 02, 2017, 03:43:49 AM »
Hi All
Thanks for reading this post.
I could do with the metal cover that goes behind the pinion flange on a 'A' axle.
It is missing from the axle I am using for my project.
Any help would be appreciated. Or advise on where I might get one.
Cheers
Paul
Living on a wing and a weld
Re: 'A' Axle Pinion Cover
June 02, 2017, 06:16:54 AM »
As far as I'm aware the cover you are referring to is actually part of the coupling flange. Some, probably those for the smaller UJ don't have one.
paulywombats
June 02, 2017, 02:36:45 PM »
Thanks olds, I remember now, this one didn't come with it, the last one I had did.
Probably not make a difference, just thought it was for keeping the seal cleaner.
paulywombats
June 03, 2017, 04:17:46 PM »
Would you believe it, I found one in one of my garage's today!!
