April 19, 2024, 08:31:59 PM *
Author Topic: Rust removal.  (Read 4296 times)
« on: May 29, 2017, 09:20:11 PM »
Been playing around with acids recently to get mill scale off hot rolled steel and found that Tricarboxylic acid (citric acid) not only works for that but is an excellent rust remover. Only really useful for items that can be put into a container and allowed to soak for a while but it can be bought in powder form very cheaply.  1 Kg cost me £5 delivered will make a huge amount when added to hot water. So far I've only used a few of tablespoons of the stuff. Pics are of a thrust washer from an huge vice I'm restoring. It was soaked in the acid for three hours. Getting mill scale off steel prior to welding or painting takes a bit longer.
« Reply #1 on: May 29, 2017, 09:55:12 PM »
That's impressive!
« Reply #2 on: May 29, 2017, 10:26:03 PM »
Possibly a large S/H hip bath full of the stuff, and insert your chassis in it Mr.M Grin...alright, alright just kiddin', can't you take a...mutter, mutter.....I've got me coat, so..... Embarrassed Embarrassed Embarrassed
« Reply #3 on: May 30, 2017, 02:39:25 PM »
 Cheesy
paulywombats
« Reply #4 on: June 01, 2017, 11:38:33 AM »
How long to get rid of a full human body? Or would it be better to dismember first?
Living on a wing and a weld
twisted
« Reply #5 on: June 01, 2017, 10:22:26 PM »
You're always gonna have problems lifting a body in one piece.
Apparently the best thing to do is cut up a corpse into six pieces and pile it all together.
Then I hear the best thing to do is feed them to pigs.
You got to starve the pigs for a few days, then the sight of a chopped-up body will look like curry to a pisshead.
You gotta shave the heads of your victims, and pull the teeth out for the sake of the piggies' digestion. You could do this afterwards, of course, but you don't want to go sievin' through pig s**t, now do you?
They will go through bone like butter.
You need at least sixteen pigs to finish the job in one sitting, so be wary of any man who keeps a pig farm.
They will go through a body that weighs 200 pounds in about eight minutes. That means that a single pig can consume two pounds of uncooked flesh every minute.
Hence the expression, "as greedy as a pig."
Baychimp
« Reply #6 on: June 01, 2017, 10:42:40 PM »
I can tell you Craig that method works a treat. .......Oops! forget I said that.
twisted
« Reply #7 on: June 02, 2017, 03:26:32 PM »
no worries sir you can come and see my pigs again anytime you want  Wink Grin
« Reply #8 on: June 02, 2017, 05:22:05 PM »
 Grin Grin
« Reply #9 on: June 02, 2017, 06:32:09 PM »
Now, I ask myself, how come he knows so much about this subject, or more importantly, why does he know so much about.....well you get my drift, I'm sure!! Mr M, you are allowing some very unsavoury characters on this site of late!!.... Huh Huh Huh Huh.... Wink
« Reply #10 on: June 02, 2017, 06:59:12 PM »
The scary bit is he's obviously thought this through before!
Way more information than I require!  Shocked
twisted
« Reply #11 on: June 02, 2017, 09:11:44 PM »
Oh you are all ok your in my good book  Wink
Also beware the man with a spade and a bag of quick Lime in the boot of his car  Wink
Night night sweet dreams
Baychimp
« Reply #12 on: June 02, 2017, 10:49:57 PM »
Forget the man. Don't look in the back of my wifes car. Shocked
