April 25, 2024, 10:29:51 PM *
Pages: 1 ... 5 6 [7] 8
Author Topic: I R S  (Read 27871 times)
« Reply #90 on: November 25, 2018, 05:39:09 PM »
Well I've been called many things ? Grin but cheers
« Reply #91 on: November 26, 2018, 08:29:56 PM »
Stinkey this may be a daft question but do you know what the drive shaft are. mild or cast steel  Huh
« Reply #92 on: November 26, 2018, 11:19:31 PM »
Well the ones I've got are definitely cast? And weld very easily ?
« Reply #93 on: November 27, 2018, 08:24:21 AM »
Thank. I did wonder as they got a seem line on them.
« Reply #94 on: November 27, 2018, 06:12:22 PM »
Helps to make sure they are warm before welding which helps
« Reply #95 on: November 27, 2018, 07:11:03 PM »
Will do thanks. what rods did you use on yours
« Reply #96 on: November 27, 2018, 07:56:39 PM »
Rods? Jeez I don't use stick welders anymore  Grin
Mig welding or Tig..
« Reply #97 on: November 27, 2018, 08:29:49 PM »
they are cast steel, not cast iron, they weld fine with a good chamfer to penetrate well down into the root. I used to always arc weld them as I felt it was a more flexible weld, where as Mig is a very brittle weld. Tig is great, but a bit hard on large shafts. Good root weld though. Check out your weld rod guy to get one for cast steel or even a dissimilar steel rod. Plenty f pre heat and give it some amps. If I had a fiver for everyone I have done as a rabbit or foreigner I'd be worth about £50-00 now  Grin Grin
« Reply #98 on: November 27, 2018, 08:30:53 PM »
I think I recall sleeving some as well ?? twas a long time back.
« Reply #99 on: November 27, 2018, 09:25:14 PM »
I got a mig and arc/tig welders. a mate is coming round to have a look
« Reply #100 on: November 27, 2018, 09:31:15 PM »
Thanks for all the information. yes they will be sleeved and plugged and well. will check out the rods I know I got mild steel rods
« Reply #101 on: November 28, 2018, 07:00:26 AM »
I love this site for helpful info from you guys..and talking of Sticks (welding rods) Mrs Stinkey came home with these today ? Roll Eyes
« Reply #102 on: December 07, 2018, 09:39:18 PM »
Axle parts are all done and are ready for painting stripped the back of the trike down so I could clean up and paint the cradle. whilst it clear at the back I will change the clutch plates
« Reply #103 on: December 21, 2018, 12:21:15 PM »
Trikes up and on its wheels. just needs tidying up and the clutch done. the first picture is what it looked like 5ft 7" wide the second is it now 4ft 9" wide.
« Reply #104 on: December 21, 2018, 02:15:11 PM »
Very nice work Terry, going to be a joy to ride.
Living on a wing and a weld
