April 25, 2024, 10:25:38 PM *
Pages: 1 [2] 3 4 ... 8
Author Topic: I R S  (Read 27870 times)
« Reply #15 on: May 21, 2017, 08:34:16 PM »
Full width jag axle is rather wide?..later jags are outboard discs..which means more weight bouncing up n Down on the wheel end ?..you can email me with your sketch ?
« Reply #16 on: May 21, 2017, 08:46:54 PM »
Thanks. I will scan it tomorrow at work then email it over
the one I tried to post from paint I lost it
Was told the diff is 35cm from drive flange to flange and 150cm wide for a xj6 model I think wont know until I go and have a look!
« Reply #17 on: May 21, 2017, 08:51:37 PM »
Tell me in inches and il understand you Shocked
« Reply #18 on: July 02, 2017, 10:44:38 AM »
Test photo
Jaguar axle fitted in a gl1500
Need to sort out the rear shocks but it set to the ride height I'm looking for
« Reply #19 on: July 02, 2017, 11:14:08 AM »
Shocks set up just need to lower the back end down. Also going to reduce the width of the axle by about 3" each side
« Last Edit: July 02, 2017, 01:52:12 PM by terry t » Logged
« Reply #20 on: July 02, 2017, 01:58:55 PM »
Coo, you've been busy.
What's holding the drive shafts at that angle & giving you the positive camber Tel? Just the shocks? -will moving the bottom mounts allow the axle to settle? Would that lower the bike too far?
« Reply #21 on: July 02, 2017, 03:15:14 PM »
Yes it just the shocks holding it up. by putting smaller or lowering them will allow the back to come down bringing the wheel back in.
I'm waiting for some gl1100 air shocks to arrive so I can set them up have a looks.
This is what I'm looking to achieve  Grin But not the shinny look Cheesy just the ride height
« Last Edit: July 02, 2017, 03:16:52 PM by terry t » Logged
« Reply #22 on: July 02, 2017, 04:24:36 PM »
« Reply #23 on: July 02, 2017, 08:04:47 PM »
Well you could always mount the shocks on (longer bolts obviously ) the bottom hub ( outer ) especially if you shorten the wishbones ?
Stix
« Reply #24 on: July 02, 2017, 08:14:21 PM »
Pooh I just made a mess 😳😳😃😃😃
« Reply #25 on: July 03, 2017, 08:02:25 AM »
Don't forget you will need some panard rods to stop the lower wishbones from moving about ?
« Reply #26 on: July 03, 2017, 08:54:02 AM »
Thanks Mate. I am going to fit them  Smiley,
It looks like the xj6 axle didn't have them fitted. may be because the wish bones are different oval in shape and the hub tips back slightly
or the cradle helped stabilize them
« Reply #27 on: July 03, 2017, 06:33:13 PM »
Maybe the anti roll bar I can see did the same job ?
« Reply #28 on: July 03, 2017, 08:32:40 PM »
The shocks came today so made the lower mounts while I'm waiting for my mate to give the axle cradle some deep penetration with his rods  Shocked .then I can start to put this together. hope to have it back on the road for Popham mega bike meet in August.
« Reply #29 on: July 04, 2017, 07:43:56 AM »
I'd brace that shock mount if I was you dude ?
