April 20, 2024, 03:39:54 PM *
Pages: 1 ... 4 5 [6] 7 8
Author Topic: I R S  (Read 27780 times)
« Reply #75 on: November 06, 2018, 09:22:32 PM »
Ideally you need a slight incline which helps with the handling ..if you look at my IRS you will see it's only slightly angled..
« Reply #76 on: November 09, 2018, 07:38:25 AM »
They work just like the shocks on a bike swing arm. Within reason, the greater the angle from vertical, the greater the wheel movement relative to spring/shock displacement. This can be used to fine tune the suspension rate without changing springs, using adjustable or multiple position top mounts.
« Reply #77 on: November 09, 2018, 08:06:49 AM »
Ditto..but I used less words Roll Eyes Grin
« Reply #78 on: November 09, 2018, 04:23:55 PM »
 Grin Grin Grin
« Reply #79 on: November 16, 2018, 09:26:10 PM »
Done a bit more to the axle. made these just need to clean them up and fit them to the axle. then work on the shafts and suspension beam
« Reply #80 on: November 16, 2018, 10:29:15 PM »
Interesting design sir..I do love seeing builds..cool
« Reply #81 on: November 17, 2018, 09:18:44 AM »
Thanks.  I was only going to have one box section at first with triangle webs each side. but thought this looked better not that you will see much when there fitted.
« Reply #82 on: November 21, 2018, 09:52:59 PM »
Got the wishbones and drive shaft cut. sorting out the upper and lower shock mounts and ride height. once I have done that I can check the drive shaft length and camber then get them welded. it ended up 51" hub face to hub face with the wheels on it will be 57" over all
« Last Edit: November 21, 2018, 10:04:57 PM by terry t » Logged
« Reply #83 on: November 23, 2018, 04:41:57 PM »
All done just need to paint it then fit it. may have to adjust the ride height when fitter
The piece of timber across the top is the width of the axle that's on the trike
« Reply #84 on: November 23, 2018, 08:08:41 PM »
I'm assuming you can adjust the camber with shims behind the driveshafts flange on the diff?.looking great sir
« Reply #85 on: November 24, 2018, 09:21:40 PM »
Thanks.Yes I can I cut an extra 4mm off the shafts to allow adjustment. just one thing can you get shims for this I was going to make some if needed
« Reply #86 on: November 25, 2018, 07:51:03 AM »
Well my local jag man gets them in but I'm sure you can find them on the internet if not locally ? But if you have cut the same amount from the driveshafts and lower arms why the need to cut driveshafts more ? Do you still have the old shims/spacers ?
« Reply #87 on: November 25, 2018, 09:10:08 AM »
I reduced both by 130mm. when I set it up at the ride height the wheel were leaning  out to get the so they were nearly upright the wish bone and drive shaft was leaning down towards the diff. so by cutting 4mm off the shafts at the set ride height they are leaning slightly and either left as is or adjusted with shims
« Reply #88 on: November 25, 2018, 11:32:10 AM »
Sounds like your on the ball good sir..
« Reply #89 on: November 25, 2018, 11:55:03 AM »
Thank you. I appreciate that coming from an experience builder  Smiley
