May 03, 2026, 08:50:05 AM *
Pages: 1 2 [3]
Author Topic: XS750  (Read 19643 times)
« Reply #30 on: May 17, 2017, 04:16:23 PM »
Nope, fully charged, and even tried them when I fired it up
flasher unit  us,, or wrong wattage builds
« Reply #31 on: May 17, 2017, 06:44:04 PM »
Thanks. Will check the bulb wattages
« Reply #32 on: May 17, 2017, 07:04:18 PM »
The more traditional, aka old fashioned, Flasher units, rely on a load of 42 watts to flash efficiently Clive, so that's 2x 12v 21 w lamps you should be using per side, Morrag
« Reply #33 on: May 17, 2017, 07:36:36 PM »
Cheers buddy. 21w each side, is that 10.5 per bulb as there's four in total (two left (front and rear), and two right (front and rear)) or am I just being thick!?!
« Reply #34 on: May 17, 2017, 07:41:32 PM »
its normally 21watts per corner  (per lamp)  == 42 watts per side
unless
you have low wattage or LED lamps,,, in the case of LED lamps you will need a resister in each lamp feed wire ,, allthough  it is possible to get aftermarket flasher units suitable for LED lamps
« Reply #35 on: May 18, 2017, 01:34:08 PM »
Thanks Mike
« Reply #36 on: May 19, 2017, 03:34:45 PM »
Well, all change, this has to go! Nothing sinister, just suddenly need the space. Will quite happily take a loss on the bits I've paid out for on it, but would like back the £800 I paid for it!
As it stands at the moment:
http://i915.photobucket.com/albums/ac360/533clive/xs750/7E2488E3-1A5C-4C51-BD74-C07A73369499_zps9pxdwsu0.jpg
XS750
And the tank, pre-clear. It's been lacquered now, but doesn't look the best, so may need the (non-artwork) main part re-doing at some stage, but it's more than acceptable:
http://i915.photobucket.com/albums/ac360/533clive/xs750/B5A1816D-E1BA-4FB7-863B-6035D72F97FD_zpsyym0qmp9.jpg
XS750
As I said, I'd like back what I paid originally, and the only thing left to sort (I think) is the indicators (or just remove them), and a bit of fettling on the seat to make it fit better.
Will obviously need trailering/vanning away, from Andover.
« Reply #37 on: May 20, 2017, 09:35:33 AM »
http://i915.photobucket.com/albums/ac360/533clive/xs750/A4C1DEE6-82CA-4895-88A2-2F224EACA48B_zps5go8ndms.jpg
XS750
http://i915.photobucket.com/albums/ac360/533clive/xs750/BBB00F49-F617-496F-8C21-708F377F540B_zpszsboydpu.jpg
XS750
http://i915.photobucket.com/albums/ac360/533clive/xs750/5E396387-79C6-405D-9362-A2A7A62374F9_zpsrmjlgykc.jpg
XS750
http://i915.photobucket.com/albums/ac360/533clive/xs750/E59D2C56-D087-422B-A405-EBB5A8B6E2ED_zpsvjmuedoj.jpg
XS750
http://i915.photobucket.com/albums/ac360/533clive/xs750/0D94225E-3C88-4D3F-BEB5-D15861113378_zpsmycupnhj.jpg
XS750
« Reply #38 on: May 20, 2017, 02:15:12 PM »
Lovely looking bike Clive.
« Reply #39 on: May 20, 2017, 03:07:00 PM »
Thanks buddy, looks like it may have just sold on eBay!
« Reply #40 on: May 20, 2017, 07:57:34 PM »
That was quick, but not surprising.
Pages: 1 2 [3]
