December 16, 2025, 04:19:46 PM
General Tech
Filler primer or primer filler
Topic: Filler primer or primer filler (Read 3642 times)
March 15, 2017, 01:47:10 PM »
As the title says, bare steel, primer or filler first ?
Sid_Vicious
Re: Filler primer or primer filler
March 15, 2017, 02:55:47 PM »
when I learned to spray paint for offshore use we always primed first before anything else....
March 15, 2017, 04:49:20 PM »
Ah but did you use body filler? I wouldn't put filler on paint, of any sort, but that's just the view of a self taught bodger...
March 15, 2017, 06:34:21 PM »
Primer first then filler but these days doesn't make much difference ?
March 15, 2017, 07:52:36 PM »
I've done a bit of both on my truck, with the appropriate amount of surface keying first, but it's quite a fine body filler.
phunkie hiboy
March 15, 2017, 07:52:49 PM »
Epoxy primer to seal the metal. Ordinary primers 1k or 2k let water in. You can fill over epoxy, sand it back a bit then fill.
