April 25, 2024, 10:50:29 PM
Wanted
17" Alloy Wheels For Reliant Axle
Topic: 17" Alloy Wheels For Reliant Axle (Read 2797 times)
paulywombats
February 02, 2017, 03:14:06 PM »
Hi All
Looking for 2 x 17" Alloy wheels to fit Reliant Axle.
What you got?
Paul 07582688469
Living on a wing and a weld
Re: 17" Alloy Wheels For Reliant Axle
February 02, 2017, 07:44:33 PM »
The reallity is you're unlikely to find any that fit properly - reliant is 4 inch, nearest fit are 100mm, which bends the studs. Apparently you can get things called "wobble nuts" which can move around relative to the stud, i have no knowledge of these. Also you can bolt adaptor plates to the hubs, if you use these make sure they're steel. Redrill the hubs and drums to 12mm is my answer - safer and cheap too.
paulywombats
February 02, 2017, 11:30:07 PM »
Thanks for the info. I am going to re drill to take 12mm studs. I'm doing the conversion to golf callipers and nova discs on this one.
Since posting also considering 16" wheels with tyres to bring to same diameter as fitting 17" wheels. Should be a more comfortable ride.
February 03, 2017, 09:53:32 PM »
I'm on 15 inchers, with tall, stiff sidewalls, at 15 psi.
paulywombats
February 04, 2017, 09:22:20 PM »
That's interesting. What make and size tyres you running?
February 05, 2017, 11:57:18 PM »
Ooo I'll have to check, but I studied the tyre charts to find the tallest ones that would fit the wheels i had, and then looked for the stiffest sidewalls. They're chinese mud and snows, will check tomorrow.
