April 19, 2026, 03:48:02 PM *
Author Topic: repositioning lug on su adapter  (Read 6649 times)
« on: January 30, 2017, 07:55:53 PM »
Just an idea i'm having, i warmed the su adapter up and managed to twist out one of the water pipe lugs, with the thought of changing it to the other side. Two problems, i cant get the blanking bit out of the other side, so if i drilled it out how would i seal the other side up and how would i seal the water pipe lug into the new position.
Anybody got any ideas ?
mrhutch
« Reply #1 on: January 30, 2017, 08:30:11 PM »
assuming there is a channel right through can you not punch the blank out from the end you removed the pipe from?
« Reply #2 on: January 30, 2017, 08:59:19 PM »
Tried that it seemed very solid so drilled through it with a smaller size drill bit just to have a look, the whole part of that adapter is hollow. So i now need to know how i can seal the hole up on the side i took the lug out of and how i can fit the lug and seal in on the other side
Stix
« Reply #3 on: January 30, 2017, 10:05:45 PM »
If you drill the blank side to give an interference fit you could heat the block and push the spigot in,then when it cools it should be a tight fit,the size of the hole will be a bit critical to ensure a tight fit. On the now open side that needs blanking, tap it out to a known size, 6-8-10 mm and fit a short bolt with a counting of a silicone sealer, if possible file or machine the face flat and square to the bore so a fibre washer can be used along with the silicone to give a good seal.
If the original spigot can't be re-used because of the size of the hole needed to get a decent hole in the alloy look about for a replacement brass spigot possibly with a thread so it could be screwed in and silicone sealed.
Stix
http://www.ebay.co.uk/itm/BRASS-PIPE-FITTINGS-BSP-1-4-TO-2-PLUMBING-/111573445907?
var=410568644080&hash=item19fa4bad13:m:mxZcf6qjZrjfKZB76zGBbhw
« Last Edit: January 30, 2017, 10:14:33 PM by Stix » Logged
Stix
« Reply #4 on: January 30, 2017, 10:16:22 PM »
On the eBay add check out the male hose tail, this sort of thing could work.
Stix
« Reply #5 on: January 30, 2017, 11:22:07 PM »
drill out and tap it to BSP  both sides  ,, plug one and screw a  nipple,,( oo,,arrr)  in the other side ,,SIMPLE,S,,  done it lots of times  but  if you get the same ,SU adapter  of a reliant kitten (4 wheeler)  they have the outlets in the position you are looking for  Wink
« Reply #6 on: January 31, 2017, 06:36:10 PM »
Thanks guys, thats a big help, for some reason i never thought of tapping it out
« Reply #7 on: February 03, 2017, 05:56:14 PM »
If there is enough material left around the hole tap a thread in. then fit threaded spigot in one and cap in the other.
« Reply #8 on: February 03, 2017, 09:50:53 PM »
Are you planning to drive this in cold - as in sub 10 degrees weather? If not why bother with the heated manifold?
« Reply #9 on: February 04, 2017, 09:46:41 AM »
Hi minimutly
Because if i remember rightly a couple of people on hear in past topics have mentioned the manifold icing up
« Reply #10 on: February 04, 2017, 08:32:39 PM »
I once had a very thin film of ice on the outside of one of mine, which wiped off with my gloved hand as I rode along, but that was after several hours of continuous motorway riding. Didn't seem to affect the running of the engine though.
Of course, on a trike, the engine's out in the airflow instead of being encased in a very small engine bay, so the windchill will drop the running temperature a few degrees.
« Reply #11 on: February 05, 2017, 02:06:45 PM »
i appreciate that, my minis have never run with manifold heating (costs power), and only once did I experience icing - cold foggy night, experimenting with a horrible glass sided downdraft - Nicky I think it was called.
So if this is a sunny day trike try it without I say.
