May 06, 2026, 02:33:35 AM *
Author Topic: XS650 - Ignition conversion to Magneto  (Read 8802 times)
« on: December 26, 2016, 12:38:16 PM »
It's quite common for folk to convert the XS650's old points & coil ignition to the new fangled electronic ignition, but here's a step that kinda goes back in time by converting the system to a magneto.
On flat-track Triumphs, the Americans often used to remove the original luacs mags, and fit (in a different location as the drive take-off pont was changed) USA-made Joe Hunt mags, which were kinda 'box-shaped' compared to the K2F Lucas round barell design.
Well, if your bank balance is strong enough (currently advertised at $979), you can fit a 'box-shaped' magneto to a XS650 lump courtesy of Morris Magneto.
http://shop.morrismagneto.com/products/yxs-for-yam-xs-650s
Couple of pics from the Morris Magneto website
« Last Edit: December 26, 2016, 12:44:17 PM by Tony oily bike » Logged
« Reply #1 on: December 26, 2016, 01:58:43 PM »
Not seen that on an XS before.
« Reply #2 on: December 26, 2016, 04:43:39 PM »
Ugly, vulnerable and why would you spoil the looks of an icon. Might have a use somewhere though.
« Reply #3 on: December 26, 2016, 05:39:29 PM »
Obviously, it'd do away with the need for a battery or coils & make a very simple wiring loom. I think the Triumph ones, mounted off the points cover on the right-hand side, look quite cool, but if you're doing it just for looks, they look less attractive high up on a Yam' engine. Certainly interesting though.
« Reply #4 on: December 26, 2016, 06:59:53 PM »
i,v got a couple of  ex WD (war department) WICO, magneto,s somewhere that are almost identical to those ,morris, magneto,s
« Reply #5 on: December 26, 2016, 10:16:56 PM »
I really want a mag but can't justify the money.
« Reply #6 on: December 26, 2016, 11:06:50 PM »
Here's a cheap mag (on more than one level)   Grin   Wink
I'll get me coat.............  Roll Eyes
« Reply #7 on: December 26, 2016, 11:36:04 PM »
 Grin Grin Grin
« Reply #8 on: December 27, 2016, 10:58:15 AM »
 Cheesy
« Reply #9 on: December 27, 2016, 07:40:24 PM »
L/H rotation  ,WICO, A, series with a twin outlet cap ==easy and fairly common, to find  then just make an adapter mount and coupling ,,
