on the axle!
on the diff housing.
Had a look but cant see out
.. Any way been propping the bits up today on bits of wood to see haw it all looks and think it will be ok
just a couple more questions.
How high is the lower frame off the ground where the engine sits on your trikes because with the forks I have to keep the frame level (as it would have been on the bike) they are about 8" off the ground (think this is a bit high as my other trike is about 3" lower)
Other trike does have bandit forks with smaller wheel but dont think it would make that much differance.
Or is it because there is no weight on the forks so at the mo they are at full length if so any ideas how much I should compress them before I start chopping things about (saw a bike build in BSH where he was on about this but cant find it at the mo)
