April 21, 2026, 01:22:55 PM *
Pages: 1 ... 14 15 [16] 17 18 ... 25
Author Topic: D72 British Bellytank  (Read 197673 times)
TerryFwit
« Reply #225 on: January 11, 2017, 09:05:26 PM »
Made up the flanges for the rear axle, getting better with the shrinker/stretcher. Might even have a go at re-doing the fuel flap if there is time. Pics will explain the process. Both sides done still need to do below the front axle but will probably do the push bar next as I have removed the rear body section at this moment.
http://i1244.photobucket.com/albums/gg579/Kevin_Bingham/Bellytank%20flanges/DSCF2222_zpsevbkhlpk.jpg
http://i1244.photobucket.com/albums/gg579/Kevin_Bingham/Bellytank%20flanges/DSCF2224_zpsd1f2wrcj.jpg
http://i1244.photobucket.com/albums/gg579/Kevin_Bingham/Bellytank%20flanges/DSCF2223_zpsfxuiuci7.jpg
http://i1244.photobucket.com/albums/gg579/Kevin_Bingham/Bellytank%20flanges/DSCF2225_zpssrhkpes6.jpg
http://i1244.photobucket.com/albums/gg579/Kevin_Bingham/Bellytank%20flanges/DSCF2226_zpsghtm39tb.jpg
http://i1244.photobucket.com/albums/gg579/Kevin_Bingham/Bellytank%20flanges/DSCF2228_zps0cd2ajac.jpg
« Last Edit: January 11, 2017, 09:27:11 PM by TerryFwit » Logged
frozennorth
« Reply #226 on: January 17, 2017, 09:23:36 PM »
Just finished reading through from the beginning, this is a really nice build; looking forward to seeing the finished article.. Smiley
TerryFwit
« Reply #227 on: January 18, 2017, 09:02:19 AM »
Cheers, so push bar next, now this is one item that we do not need as the car has its own starter and is geared  low enough to start from a stand still unlike a real lakester. Plus I don't believe you can push start an automatic. So a simple frame work was made to bolt on behind the fuel tank to hold the push bar.
Started with notch in the fuel tank mount so we can fit a bracket behind it.
http://i1244.photobucket.com/albums/gg579/Kevin_Bingham/Bellytank%20mounts/DSCF2233_zpsui2b7ugw.jpg
http://i1244.photobucket.com/albums/gg579/Kevin_Bingham/Bellytank%20mounts/DSCF2234_zpsz7f5um1f.jpg
Cut the already bent piece to length.
 http://i1244.photobucket.com/albums/gg579/Kevin_Bingham/Bellytank%20mounts/DSCF2235_zpsfw4rckkw.jpg
Drilled a hole in the tail for the push bar.
http://i1244.photobucket.com/albums/gg579/Kevin_Bingham/Bellytank%20mounts/DSCF2237_zpskk5eiisw.jpg
http://i1244.photobucket.com/albums/gg579/Kevin_Bingham/Bellytank%20mounts/DSCF2238_zpsdtn8xcta.jpg
Made the 'T' bar which is to be removable for storage reasons, 8" is valuable hoarding room in lockup.
http://i1244.photobucket.com/albums/gg579/Kevin_Bingham/Bellytank%20mounts/DSCF2239_zps3qkndsui.jpg
Bolted the plate to go behind the fuel tank mount to the chassis.
http://i1244.photobucket.com/albums/gg579/Kevin_Bingham/Bellytank%20mounts/DSCF2240_zpsfc1mrv07.jpg
Welded top of frame to the bracket that goes behind fuel tank and a lower bar from the rear axle body mount.
http://i1244.photobucket.com/albums/gg579/Kevin_Bingham/Bellytank%20mounts/DSCF2249_zpsckwnqctn.jpg
All back to the rear .http://i1244.photobucket.com/albums/gg579/Kevin_Bingham/Bellytank%20mounts/DSCF2250_zpsllsjhpn1.jpg
Looking like this.http://i1244.photobucket.com/albums/gg579/Kevin_Bingham/Bellytank%20mounts/DSCF2248_zpsxh7la4ql.jpg
And fuel tank back in.
http://i1244.photobucket.com/albums/gg579/Kevin_Bingham/Bellytank%20mounts/DSCF2251_zpsrepwvbkb.jpg
We now have a mount which I will shorten and drill a hole through for a retaining bolt to hold the 'T'bar.
http://i1244.photobucket.com/albums/gg579/Kevin_Bingham/Bellytank%20mounts/DSCF2254_zpstxhftde5.jpg
And done. (ish)
http://i1244.photobucket.com/albums/gg579/Kevin_Bingham/Bellytank%20mounts/DSCF2253_zps0bneh7qw.jpg
http://i1244.photobucket.com/albums/gg579/Kevin_Bingham/Bellytank%20mounts/DSCF2252_zpsigaszt5o.jpg
TerryFwit
« Reply #228 on: January 19, 2017, 06:44:47 PM »
Pushed the car outside to get a look . Even though the car is not on level ground you can see the bottom needs more trimming so pushed back in and started strip down for marking up new cut line.
http://i1244.photobucket.com/albums/gg579/Kevin_Bingham/Bellytank/DSCF2257_zpsc3tb5r2x.jpg
http://i1244.photobucket.com/albums/gg579/Kevin_Bingham/Bellytank/DSCF2262_zpscret7qq1.jpg
http://i1244.photobucket.com/albums/gg579/Kevin_Bingham/Bellytank/DSCF2263_zpssdycdwpr.jpg
« Last Edit: February 08, 2017, 06:59:06 PM by TerryFwit » Logged
« Reply #229 on: January 19, 2017, 07:04:59 PM »
not checked in for a while, omg amazing work. looks brilliant.
« Reply #230 on: January 19, 2017, 07:52:04 PM »
Looks fabulous. So will you be leaving the bottom open to the road/track, or adding a flat floor panel?
« Reply #231 on: January 19, 2017, 08:56:57 PM »
speechless...looks brilliant
TerryFwit
« Reply #232 on: January 20, 2017, 04:54:42 PM »
Thanks for the positive comments. The floor is going to be flat with more vents in the side of the bottom body.
Pushed car over the pit and removed most of the internal parts so a new cut line  could be marked.
 http://i1244.photobucket.com/albums/gg579/Kevin_Bingham/Bellytank%20cuts/DSCF2265_zpsuybql1qi.jpg
http://i1244.photobucket.com/albums/gg579/Kevin_Bingham/Bellytank%20cuts/DSCF2266_zps1g9sbtoi.jpg
Then made sure car was level before putting a self leveling spinning laser thingy on a tripod in the pit with the laser shinning inside the body, not the best thing to take a picture off.
http://i1244.photobucket.com/albums/gg579/Kevin_Bingham/Bellytank%20cuts/DSCF2272_zpsd8lsiy3b.jpg
Lights back on and pit boards back in, and the perfect new cut line for a flat bottom.
http://i1244.photobucket.com/albums/gg579/Kevin_Bingham/Bellytank%20cuts/DSCF2273_zpsqiswvd9t.jpg
http://i1244.photobucket.com/albums/gg579/Kevin_Bingham/Bellytank%20cuts/DSCF2274_zpsnneg9rmq.jpg
http://i1244.photobucket.com/albums/gg579/Kevin_Bingham/Bellytank%20cuts/DSCF2275_zpslmkamkyw.jpg
http://i1244.photobucket.com/albums/gg579/Kevin_Bingham/Bellytank%20cuts/DSCF2276_zpsjqstx3lm.jpg
TerryFwit
« Reply #233 on: January 20, 2017, 05:19:23 PM »
Most of the fabrication is done now, most problems solved so stripped the rest down for final welding/grinding/shaping and tabs. Finish all that soon then paint and start the real build up.
May not be much to post unless you really want to literally watch paint dry. Grin
Only risk now, is if I get bored/distracted by something else, this may get parked up next to the trike and left for a bit (5 years) Roll Eyes
Apparently I am showing early signs of post project blues. Grin
http://i1244.photobucket.com/albums/gg579/Kevin_Bingham/Bellytank%20Chassis/DSCF2280_zpslsuv1fgq.jpg
http://i1244.photobucket.com/albums/gg579/Kevin_Bingham/Bellytank%20Chassis/DSCF2282_zpsoznnbbnd.jpg
http://i1244.photobucket.com/albums/gg579/Kevin_Bingham/Bellytank%20Body/DSCF2284_zpsjqmq0ba5.jpg
« Last Edit: February 08, 2017, 07:02:52 PM by TerryFwit » Logged
« Reply #234 on: January 20, 2017, 05:30:57 PM »
Looks absolutely rad, you must be stoked on it.
TerryFwit
« Reply #235 on: January 20, 2017, 06:55:00 PM »
Err.... Yeah, sweet innit bruv , laters. Grin
Yes, I am rather pleased.
« Reply #236 on: January 20, 2017, 08:03:22 PM »
Sorry -Archie's our resident yoof. It's in the rules -we have to have one for every 10 old fogies.
Don't abandon it now please -I'm really looking forward to watching this run at Shakey this year -if you need a tow truck I might know of a V8 Pop pick-up that'll be at the Hotrod Drags & Nostalgia Nationals.  Smiley
TerryFwit
« Reply #237 on: January 20, 2017, 10:28:09 PM »
No chance of stopping now, but the mind does wander.
Nearly did stop the whole project about a year ago when this stupid dog of mine jumped out the bedroom window resulting in a leg like this.
http://i1244.photobucket.com/albums/gg579/Kevin_Bingham/Pikey%20Dag/DSCF1621_zpsdn9o8zar.jpg
No local vets could fix it so they sent me to these nice people. Fitzpatrick referrals.  The TV supervet.
http://i1244.photobucket.com/albums/gg579/Kevin_Bingham/Pikey%20Dag/DSCF1622_zpsz1tovcc8.jpg
Who did this
http://i1244.photobucket.com/albums/gg579/Kevin_Bingham/Pikey%20Dag/00000000_DICOM_DX_2016_04_19_0003844276_zpsjilzdzel.jpg
Gave me back a drugged up dog like this.
http://i1244.photobucket.com/albums/gg579/Kevin_Bingham/Pikey%20Dag/DSCF1638_zpsn1ovnuga.jpg
And told me to keep him in here for 8 weeks.  Yeah right oh.
http://i1244.photobucket.com/albums/gg579/Kevin_Bingham/Pikey%20Dag/DSCF1645_zpszefo1nyo.jpg
Oh and a total bill (no insurance) of £3300...... Shocked
Project funds took a hammering.
« Last Edit: February 07, 2017, 07:58:01 PM by TerryFwit » Logged
« Reply #238 on: January 21, 2017, 07:20:50 AM »
Ouch!
« Reply #239 on: January 21, 2017, 03:07:09 PM »
Maybe, but you have obviously got your priorities right! and your build is classic, so...all is well with the world, and what's a little time, eh?...Morrag
