TerryFwit
« Reply #135 on: December 10, 2016, 05:48:03 PM » |
 D72 British Bellytank Seat is just sat on two brackets at the moment.
TerryFwit
« Reply #136 on: December 10, 2016, 05:50:51 PM » |
 D72 British Bellytank And two tabs at the back.
TerryFwit
« Reply #137 on: December 10, 2016, 05:57:52 PM » |
 D72 British Bellytank Put a bar across for the shoulder straps. Made sure we had enough clearance to still get a socket on the nuts for the seat mounts.
TerryFwit
« Reply #138 on: December 10, 2016, 06:02:20 PM » |
 D72 British Bellytank Decided on best place for lap belt mounts.  D72 British Bellytank Welded in a bracket for the harness eyelet.
TerryFwit
« Reply #139 on: December 10, 2016, 06:10:55 PM » |
 D72 British Bellytank Looked at the bottom mount and needed somewhere for the crotch mount and felt we needed a bit more protection,  D72 British Bellytank And put in this brace made from an old metal pallet foot. Must be 1/4" thick and runs directly under the drivers most delicate parts in case we ground out anytime.
« Reply #140 on: December 10, 2016, 06:12:32 PM » |
You just have got to put some holes in that front axle ?
TerryFwit
« Reply #141 on: December 10, 2016, 06:20:55 PM » |
Holes in the axle was always part of the plan but may be a winter job once finished as time is running out at the moment.
TerryFwit
« Reply #142 on: December 10, 2016, 06:24:01 PM » |
 D72 British Bellytank Put some holes in the seat instead.
TerryFwit
« Reply #143 on: December 10, 2016, 08:25:36 PM » |
 D72 British Bellytank  D72 British Bellytank Holes in the side is the start of the lapbelt slots.  D72 British Bellytank Bit between cut out, will maybe make larger and flange the edges a little bit.
« Last Edit: February 10, 2017, 10:20:37 PM by TerryFwit »
TerryFwit
« Reply #144 on: December 10, 2016, 08:28:19 PM » |
 D72 British Bellytank Worked out where the crotch strap mount would be in seat base.
TerryFwit
« Reply #145 on: December 10, 2016, 08:32:32 PM » |
 D72 British Bellytank Put the shoulder straps round the rear tube. Clipped in the lap belts each side.  D72 British Bellytank
TerryFwit
« Reply #146 on: December 10, 2016, 08:35:27 PM » |
 D72 British Bellytank Popped the seat in and fed the lap belts through the side slots.  D72 British Bellytank
TerryFwit
« Reply #147 on: December 10, 2016, 08:45:47 PM » |
Put another eyelet through the lower seat brace which comes out the hole in the seat and connects to the crotch belt. Job done! 5 point harness and seat to keep us safe. Bit more to finish but will do towards the end. Radiator, battery and fuel tank next.  D72 British Bellytank  D72 British Bellytank
« Reply #148 on: December 11, 2016, 09:13:51 AM » |
Nice. Swages look good too. Are there regulations on the clearance around the lap belt slots? Rubber edging bead to stop them chafing? A really interesting build.
TerryFwit
« Reply #149 on: December 11, 2016, 04:06:38 PM » |
May well be regulations but not for RWYB, as long as they are there and undamaged. Have some edging to go on the seat and was going to flare the harness slots for clearance. If that fails will just make slots larger and use the edging on them.
