April 19, 2026, 04:39:52 PM *
Pages: 1 ... 4 5 [6] 7 8 ... 25
Author Topic: D72 British Bellytank  (Read 194013 times)
TerryFwit
« Reply #75 on: October 22, 2016, 08:20:23 AM »
http://i1244.photobucket.com/albums/gg579/Kevin_Bingham/Bellytank%20Body%20Cuts/IMG_6244_zpszclr7tde.jpg
With the top on roughly and knowing where the seat would now be we marked out a possible hole and then cut away the minimum required to at least get an idea for the height of the roll hoop behind driver.
« Last Edit: February 12, 2017, 10:42:19 AM by TerryFwit » Logged
TerryFwit
« Reply #76 on: October 22, 2016, 08:35:48 AM »
http://i.imgur.com/kskZC2U.jpg
Top off and the roll hoop in place.
« Last Edit: April 15, 2017, 07:04:51 AM by TerryFwit » Logged
TerryFwit
« Reply #77 on: October 22, 2016, 08:46:12 AM »
http://i.imgur.com/Klw6uyu.jpg
With the hoop in and body back on we could now start the spine.
Made a very thin section of the body and placed over the main body before marking out with tape the rough idea of what we wanted.
« Last Edit: April 15, 2017, 07:12:46 AM by TerryFwit » Logged
TerryFwit
« Reply #78 on: October 22, 2016, 08:48:16 AM »
http://i.imgur.com/Sq3ZMJF.jpg
« Last Edit: April 15, 2017, 07:13:42 AM by TerryFwit » Logged
TerryFwit
« Reply #79 on: October 22, 2016, 08:49:19 AM »
http://i.imgur.com/1dJAPYg.jpg
« Last Edit: April 15, 2017, 07:14:40 AM by TerryFwit » Logged
TerryFwit
« Reply #80 on: October 22, 2016, 08:52:01 AM »
http://i.imgur.com/qCuNqb2.jpg
All planned, just need to make out of something.
« Last Edit: April 15, 2017, 07:16:08 AM by TerryFwit » Logged
« Reply #81 on: October 22, 2016, 09:33:14 AM »
Nice progress. Loving it.
« Reply #82 on: October 22, 2016, 10:50:52 AM »
Looking great guys. I was wondering what you were doing about cooling, but see you've got a rad' laid on top of the gearbox. I kinda assumed you'd leave the bottom of the body open & lay the rad' flat underneath -obviously it'd be very vulnerable but it ain't exactly a road going vehicle, (it'd be cool if it was though). Will you be adding scoops to that new section of body?
And a motor plate between those spinning pulleys & the back of your head might be nice Smiley
Here's an ali' bodied 'tank racer I saw at the Rockin' Jalopys show in Holland in 2014.
« Reply #83 on: October 22, 2016, 12:01:42 PM »
http://i1244.photobucket.com/albums/gg579/Kevin_Bingham/Belltank%20chassis%20mods/IMG_6244_zpsyju3pskf.jpg
With the top on roughly and knowing where the seat would now be we marked out a possible hole and then cut away the minimum required to a least get and idea for the height of the roll hoop behind driver.
Where did you get that HEAD from ? Will that be your HEADLIGHT ? Roll Eyes
TerryFwit
« Reply #84 on: October 22, 2016, 01:43:47 PM »
Cheers chaps, we were going to fit a rad underneath between the rails but clearance would have been tight and vulnerable, so next best place was above gearbox. A plate will be going across the seat back by the pulleys  for my own piece of mind after we have worked out the 5 point harness mounts. Everything from the firewall forward will be enclosed under the seat. Will post pics of the rest after the spine.
If there are too many pics or you see anything wrong/stupid please do say.
Kev.
« Last Edit: October 22, 2016, 01:48:53 PM by TerryFwit » Logged
« Reply #85 on: October 22, 2016, 02:35:59 PM »
Been quietly watching this build from the side lines, and am finding it really interesting, partly from a tech perspective and partly as its properly different.
Have to say am also impressed by the rate of progress, keep up the good work!  Wink
TerryFwit
« Reply #86 on: October 22, 2016, 04:41:44 PM »
http://i.imgur.com/GhIxdxF.jpg
To make the spine I used a different method this time, instead of polystyrene I used a sheet of insulation this time as I discovered the insulation did not react with the filler, so no sealing with PVA before filling.
Used a bread knife to cut rough shapes before sticking on with 'sticks like s**t'. Honest.
« Last Edit: April 15, 2017, 07:19:21 AM by TerryFwit » Logged
TerryFwit
« Reply #87 on: October 22, 2016, 04:44:33 PM »
http://i.imgur.com/U7DohVj.jpg
Way more than needed, but easier to remove now than add with filler later.
« Last Edit: April 15, 2017, 07:22:30 AM by TerryFwit » Logged
TerryFwit
« Reply #88 on: October 22, 2016, 04:45:57 PM »
http://i1244.photobucket.com/albums/gg579/Kevin_Bingham/Bellytank%20spine/DSCF1563_zps3ccrimbl.jpg
First sanding.
TerryFwit
« Reply #89 on: October 22, 2016, 04:47:08 PM »
http://i1244.photobucket.com/albums/gg579/Kevin_Bingham/Bellytank%20spine/DSCF1564_zpshk66orzm.jpg
