April 19, 2026, 06:57:40 AM *
Pages: 1 ... 17 18 [19] 20 21 ... 25
Author Topic: D72 British Bellytank  (Read 193689 times)
« Reply #270 on: February 26, 2017, 03:47:42 PM »
Certainly pleased me at least ? Wink
« Reply #271 on: February 26, 2017, 05:17:22 PM »
Very nicely done, I do like this piece, really....................... Grin Grin Grin Grin
« Reply #272 on: February 26, 2017, 09:38:11 PM »
I was thinking that!!!   Grin Grin Grin
TerryFwit
« Reply #273 on: March 03, 2017, 12:19:34 AM »
Cleaned up and painted the new bits
http://i.imgur.com/OogVggY.jpg
http://i.imgur.com/NHyhyPi.jpg
http://i.imgur.com/plDDoDq.jpg
http://i.imgur.com/lTMSUvB.jpg
Also removed the front spring to clean up, didn't want to paint so used this stuff, works really well.
http://i.imgur.com/LyYZYLU.jpg
http://i.imgur.com/67D5c3d.jpg
http://i.imgur.com/TZVUr80.jpg
http://i.imgur.com/2bWdql6.jpg
http://i.imgur.com/yuKbGSv.jpg
Trimmed up the bottom body section
http://i.imgur.com/kcemoRq.jpg
http://i.imgur.com/vRWzMXQ.jpg
http://i.imgur.com/uLoMHxx.jpg
http://i.imgur.com/gvL6U4W.jpg
http://i.imgur.com/t8juDzb.jpg
TerryFwit
« Reply #274 on: March 03, 2017, 12:29:47 AM »
Brought a new kill switch for the dash
http://i.imgur.com/B49w9T2.jpg
http://i.imgur.com/6Dt6MLV.jpg
Still have one more switch to fit yet but decided to 'bling' it up first
 http://i.imgur.com/ROfbpaO.jpg
Quick spray with clearcoat and soon back together.
« Reply #275 on: March 03, 2017, 11:10:43 AM »
Oh that dash is pretty!
« Reply #276 on: March 03, 2017, 05:33:58 PM »
What spec is the engine going to be?
« Reply #277 on: March 03, 2017, 08:09:32 PM »
The grate blacking's a good idea. Hadn't thought of that. Had the same problem with mine -how do you weather proof it cos paint will just rub off when the leaves move. I ended up greasing mine up & wrapping it in a vinyl sleeve, 30s touring car style.
TerryFwit
« Reply #278 on: March 03, 2017, 08:55:14 PM »
From memory as have been slowly buying parts
Rover V8 4.0 litre which we now believe to be from a defender?
Stump Puller cam (came with the block)
Standard heads but some special type of valves?
Uprated springs caps and shims
Edelbrock Manifold
Holley 390cfm carb
Rhodes hydraulic lifters
Coyles timing chain set
ARP udjustable pushrods
ARP headset
ARP manifold bolts
ARP header bolts
MSD distributor
Maybe some other bits as well.
Block and distributor are secondhand everything else brand new but purchased over time so not to make me cry when I add it all up. Grin
TerryFwit
« Reply #279 on: April 15, 2017, 08:58:20 PM »
So, been a while, had some bad news my dad was taken ill suddenly and diagnosed with terminal cancer. Not good, could have walked away from this so easily but have decided, Sod it!, I am going to do all 3 things this year. 1 Visit my dad as much as possible (330 mile round trip) 2. Finish this car 3. Go racing as much as possible.
But, if the worse happens, who knows.
On a happy note , life came and kicked me in the balls again and my van decided to start playing up- throttle position sensor- changed it fine 2 days later back again. Not funny when van will not accelerate above tickover at all and your on the M4. And needing a vehicle to visit dad at any moment spent £3400 on a (reliable)car and insurance. All this almost a year to the day the Dag took a swan dive out the window and cost £3300.
I really should not be spending on this car, but I need to finish it.
Anyways, on with the build.
Made a template of the roll hoop for the headrest.
http://i.imgur.com/Eh9uZcv.jpg
Bit of CAD design
http://i.imgur.com/SscLuE0.jpg
Piece of Ali for the back
http://i.imgur.com/28tPfQG.jpg
Foam cut to size
http://i.imgur.com/ppOi9ri.jpg
Ply cut to size
http://i.imgur.com/7NtwqG9.jpg
Found the top of the curve was separating
http://i.imgur.com/yskoI9g.jpg
Cut another one
http://i.imgur.com/MeLz4zZ.jpg
Test fitted before covering in foam.
http://i.imgur.com/4rct3tf.jpg
Fixings will be shortened and replaced with mushroom bolts once plate has been polished up a bit.
http://i.imgur.com/LsQ1E6E.jpg
« Reply #280 on: April 15, 2017, 10:08:52 PM »
There's more important things than vehicles mate.
I've got a new lady in my life, but she's currently sat in a hospital in Brighton watching her 20 year old son in intensive care, (possible rejection of a bowel transplant). Yes, I'm on call if she needs me.
Life's short & the older you get, the more acutely aware of that you become. If the car takes your mind off things & makes you smile, do it, but if you need to do other stuff, it'll still be there when you come back.
Looking good. Really hope to see it out this year.  Smiley
TerryFwit
« Reply #281 on: April 15, 2017, 10:15:19 PM »
Also cut a piece for the seat with hole for the harness.
http://i.imgur.com/bacVhBj.jpg
Took the bottom body to Jamie's workshop to put the flat bottom in.
http://i.imgur.com/v8PF86N.jpg
And then had a plan for something pointless and time consuming. Popped along to H.C.S Carpetcare Ltd and got talking to the owner Adrian about it. Turns out he trained as an Aircraft engineer but ended up running a carpet binding company and was really interested in the tank and offered me a length of Italian leather at a price I could not refuse. Thank you very much. Had the plan and gathered together the parts.
http://i.imgur.com/WT9gVaA.jpg
TerryFwit
« Reply #282 on: April 15, 2017, 10:22:49 PM »
Life can be difficult sometimes but I must admit the last few days working on the car inbetween visiting dad has really lifted my spirits some what and given me something to do instead of pondering about the future.
TerryFwit
« Reply #283 on: April 15, 2017, 10:43:14 PM »
Leather is 4 1/2" wide which was too wide and I need one good edge so marked out 2" line
http://i.imgur.com/2zIQP7u.jpg
Then stuck a length of 1" double side tape
http://i.imgur.com/Suc7dLO.jpg
Peel back carefully, sticks like crazy to anything
http://i.imgur.com/21Htuon.jpg
Fold over to line
http://i.imgur.com/PGLnAgx.jpg
You only get one go with this tape and the natural backing to the leather
http://i.imgur.com/IEXbdFk.jpg
Done
http://i.imgur.com/uHBh8Z1.jpg
Other side
http://i.imgur.com/297kERH.jpg
Marked out every 1 1/2"
http://i.imgur.com/fiw3SP5.jpg
Punched out
http://i.imgur.com/hiIUNNO.jpg
4 mm Brass eyelets fitted
http://i.imgur.com/UC8AXjr.jpg
And now I have a finished edge to start with
http://i.imgur.com/9As2rb5.jpg
TerryFwit
« Reply #284 on: April 15, 2017, 10:54:45 PM »
Marked out the other side but did not turn the edge
http://i.imgur.com/2x5RUql.jpg
Finished side like this
http://i.imgur.com/aKZ8kAU.jpg
Told you it took a long time Grin
http://i.imgur.com/jYkPPy9.jpg
