April 19, 2026, 10:10:43 AM *
Pages: 1 ... 13 14 [15] 16 17 ... 25
Author Topic: D72 British Bellytank  (Read 193770 times)
« Reply #210 on: January 06, 2017, 09:33:42 PM »
I'm in awe!
TerryFwit
« Reply #211 on: January 07, 2017, 06:13:51 PM »
Thank you, right had enough of flaps at the moment so had a go at flange instead. Grin
No really, started on the exhaust flanges. Cut some strips of thin steel about an inch wide and fold down their length in half making lengths of angle. Found an offcut of tube about 62mm as a guide and start stretching.
http://i1244.photobucket.com/albums/gg579/Kevin_Bingham/Bellytank%20zoomies/DSCF2107_zpspnqnfjyd.jpg
http://i1244.photobucket.com/albums/gg579/Kevin_Bingham/Bellytank%20zoomies/DSCF2109_zpsmvsvqkfw.jpg
And one ready made flange kit. Bent up more than needed and cut the straight bits to 18". You can see the offcut used as a guide top right of pic.
http://i1244.photobucket.com/albums/gg579/Kevin_Bingham/Bellytank%20zoomies/DSCF2110_zpshs4mdm6z.jpg
Enlarged the slots to about 65mm and rounded out the ends.
http://i1244.photobucket.com/albums/gg579/Kevin_Bingham/Bellytank%20zoomies/DSCF2118_zps511y76at.jpg
Test fitted the best of the end pieces.
http://i1244.photobucket.com/albums/gg579/Kevin_Bingham/Bellytank%20zoomies/DSCF2119_zpsewlcwzlq.jpg
Fitted the top and bottom sections first in the same way as the air vents 5mm dome head allen bolts
http://i1244.photobucket.com/albums/gg579/Kevin_Bingham/Bellytank%20zoomies/DSCF2121_zpstnnl5ofq.jpg
Then trimmed up the end pieces to match, just need to tack together before removing and final welding.
http://i1244.photobucket.com/albums/gg579/Kevin_Bingham/Bellytank%20zoomies/DSCF2122_zpsabnagtkw.jpg
Exhaust refitted.
http://i1244.photobucket.com/albums/gg579/Kevin_Bingham/Bellytank%20zoomies/DSCF2125_zpstwqxwngw.jpg
« Reply #212 on: January 07, 2017, 09:27:45 PM »
That really is a wondrous tool isn't it -oh, how many times have I heard that over the years ...well, not that many actually.
Could've really used that on a few builds. The details are really putting this project one notch higher than most -there's been a steel belly tank racer -well, aluminium I guess, at the Dutch hotrod show I go to for the last couple of years. Very nice, but not finished to anywhere near the standard of your 'glass one.
« Last Edit: January 08, 2017, 09:51:23 AM by Manky Monkey » Logged
TerryFwit
« Reply #213 on: January 07, 2017, 10:36:47 PM »
Thanks for the positive comments, problem with building something is you know all the little flaws which always draw your eye preventing you from seeing the whole product. Or is that just me ?
Anyways going to cut the body again next.
Kev.
« Reply #214 on: January 08, 2017, 09:53:00 AM »
Yup. Joe Public just see a nice car, or bike, or bellytank. If you've built it you know every ripple in the bodywork, every flaw in the paint etc.
TerryFwit
« Reply #215 on: January 08, 2017, 05:00:38 PM »
After the fuel flap disaster we still needed another one this time at the front. This is so we can access the brake fluid reservoir and the fuse box, was never keen on this as in 5 years of racing the trabant we have at the track changed one fuse and topped up the fluid once. The others insisted it was accessible so, after many hours of just staring at it I decide to make whole front removable and using the minimum amount of cuts required.
Marked out the cuts with masking tape, carrying on the engine cover cut all the way down to the lip.
http://i1244.photobucket.com/albums/gg579/Kevin_Bingham/Bellytank%20cuts/DSCF2136_zpsmh3kkap8.jpg
http://i1244.photobucket.com/albums/gg579/Kevin_Bingham/Bellytank%20cuts/DSCF2140_zpswe2bpmxy.jpg
And two cuts behind the roll hoop.
http://i1244.photobucket.com/albums/gg579/Kevin_Bingham/Bellytank%20cuts/DSCF2143_zpsahubcqi4.jpg
Meaning this whole section from the tape forwards will be removable.
http://i1244.photobucket.com/albums/gg579/Kevin_Bingham/Bellytank%20cuts/DSCF2141_zpsuqbqmzpk.jpg
TerryFwit
« Reply #216 on: January 08, 2017, 05:07:53 PM »
Removed the firewall flange.
http://i1244.photobucket.com/albums/gg579/Kevin_Bingham/Bellytank%20cuts/DSCF2144_zpspeudtxwv.jpg
And cut down to the lip.
http://i1244.photobucket.com/albums/gg579/Kevin_Bingham/Bellytank%20cuts/DSCF2146_zpshhef7mb0.jpg
Did the same on the other side and then took front off before cutting away the top piece.
http://i1244.photobucket.com/albums/gg579/Kevin_Bingham/Bellytank%20cuts/DSCF2147_zps3wgm91pm.jpg
http://i1244.photobucket.com/albums/gg579/Kevin_Bingham/Bellytank%20cuts/DSCF2148_zpsbd9lq6sj.jpg
« Last Edit: January 09, 2017, 09:03:18 PM by TerryFwit » Logged
TerryFwit
« Reply #217 on: January 08, 2017, 07:24:13 PM »
Ending up with this.
http://i1244.photobucket.com/albums/gg579/Kevin_Bingham/Bellytank%20cuts/DSCF2149_zpse0yt2wt2.jpg
Or this
http://i1244.photobucket.com/albums/gg579/Kevin_Bingham/Bellytank%20cuts/DSCF2150_zpsxwyv5swc.jpg
Or this
http://i1244.photobucket.com/albums/gg579/Kevin_Bingham/Bellytank%20cuts/DSCF2152_zps5dtshcyu.jpg
And together
http://i1244.photobucket.com/albums/gg579/Kevin_Bingham/Bellytank%20cuts/DSCF2151_zpsgggx3o89.jpg
And as a little treat I put it all back together and ended up with this.
http://i1244.photobucket.com/albums/gg579/Kevin_Bingham/Bellytank%20cuts/DSCF2156_zpsmlw7jecv.jpg
Rather pleased....still don't like the fuel flap. Grin
« Reply #218 on: January 08, 2017, 07:42:30 PM »
For a minute there I thought you were going backwards & making a huge change that might not work out -but I shouldn't have doubted you -very sensible to have the front removable & everything still seems to line up perfectly when it goes back on. In the event of a crash/fire/change of underpants etc, some quick release Dzus fasteners would mean quick access to the cockpit area -makes perfect sense.
TerryFwit
« Reply #219 on: January 10, 2017, 07:05:54 PM »
Front section will still be bolted together, in total 35 bolts. Will only take 5 -10 mins to remove. The others wanted 'serviceable' well I gave them 'accessible'  Grin
On with the front section, marked up with masking tape the shape of the opening around the spring and shock.
http://i1244.photobucket.com/albums/gg579/Kevin_Bingham/Bellytank%20flanges/DSCF2181_zpsglsdmti1.jpg
Cut away and checked for clearance.
http://i1244.photobucket.com/albums/gg579/Kevin_Bingham/Bellytank%20flanges/DSCF2182_zpsusx5p8mh.jpg
Then made a template for other side.
http://i1244.photobucket.com/albums/gg579/Kevin_Bingham/Bellytank%20flanges/DSCF2184_zpscxvltydg.jpg
http://i1244.photobucket.com/albums/gg579/Kevin_Bingham/Bellytank%20flanges/DSCF2185_zpsyxyqkeqw.jpg
And then marked up the other side.
http://i1244.photobucket.com/albums/gg579/Kevin_Bingham/Bellytank%20flanges/DSCF2186_zpscpj5beex.jpg
Cut that piece out and hoped they matched.
http://i1244.photobucket.com/albums/gg579/Kevin_Bingham/Bellytank%20flanges/DSCF2187_zpswb0nt07a.jpg
And checked back on the car, so far so good. Next more flanges.
http://i1244.photobucket.com/albums/gg579/Kevin_Bingham/Bellytank%20flanges/DSCF2190_zpsyppa9ymr.jpg
TerryFwit
« Reply #220 on: January 10, 2017, 07:25:21 PM »
Made flanges in the same way as all the others, Little bits all shrunk and stretched to the right shape before being welded together which is not done yet as that is one thing I cannot do. No point trying as the others can all weld so leave it to the experts.
http://i1244.photobucket.com/albums/gg579/Kevin_Bingham/Bellytank%20flanges/DSCF2193_zps6qhkjfmp.jpg
http://i1244.photobucket.com/albums/gg579/Kevin_Bingham/Bellytank%20flanges/DSCF2194_zpsikzhy0km.jpg
http://i1244.photobucket.com/albums/gg579/Kevin_Bingham/Bellytank%20flanges/DSCF2195_zpsvfc6dbg9.jpg
http://i1244.photobucket.com/albums/gg579/Kevin_Bingham/Bellytank%20flanges/DSCF2197_zpsg492pp0j.jpg
A quick check before fixing and trimming.http://i1244.photobucket.com/albums/gg579/Kevin_Bingham/Bellytank%20flanges/DSCF2198_zpsnfokr1yg.jpg
And one side done.
http://i1244.photobucket.com/albums/gg579/Kevin_Bingham/Bellytank%20flanges/DSCF2208_zps8bwyapgt.jpg
Made the same for the other side.
http://i1244.photobucket.com/albums/gg579/Kevin_Bingham/Bellytank%20flanges/DSCF2211_zpszsnwb92b.jpg
Checked to see if this one fits.
http://i1244.photobucket.com/albums/gg579/Kevin_Bingham/Bellytank%20flanges/DSCF2217_zpsxv0ssneb.jpg
And done, and they look quite equal and in line so happy with that. Next up rear axle openings and yep, more flanges.
http://i1244.photobucket.com/albums/gg579/Kevin_Bingham/Bellytank%20flanges/DSCF2221_zpsz4b7yrcf.jpg
« Reply #221 on: January 10, 2017, 07:30:21 PM »
I do like that shrinky doofer.
What are your lever arm shocks from? Sherpa, (I cut a Sherpa van up a few years ago but can't remember what dampers it had). My Pop uses the rear lever arms from a Moggy Minor, but if I'm driving on my own, the body settles to the driver's side. I wonder if stiffer dampers would help.
TerryFwit
« Reply #222 on: January 10, 2017, 07:37:53 PM »
I think they came off an old ford Pop from memory and the spring is from a morris 8. Basically using what ever is tucked away in our garages.
« Reply #223 on: January 11, 2017, 05:30:26 PM »
No Andy, shock absorbers, or dampers are just that. Springs hold you up. Fit stiffer springs, move them out, or fit an antirollbar. Maybe all 3?
« Reply #224 on: January 11, 2017, 05:48:20 PM »
I've got a transverse leaf on the front, the same as Terry's bellytank, so can't do any of those.
