December 17, 2025, 01:03:52 AM *
Pages: 1 2 [3] 4 5 6
Author Topic: New build  (Read 59004 times)
MIXA
« Reply #30 on: November 11, 2016, 08:45:02 PM »
I had a spine op in 2012 that stopped my riding inc the trike , had misses with me once and the surgeon told her i was brain dead if i thought i could ride again , she said hes going to use a trike not sure what his reply was but she said its going now
« Reply #31 on: November 11, 2016, 09:25:46 PM »
I kept riding as long as I could but when it was off the road due to an axle problem and I noticed that even a nice day didn't make me wish I was riding, it was probably time to give in!
MIXA
« Reply #32 on: November 14, 2016, 08:06:13 PM »
Sounds like the right time to stop ,hard but some times for the best
All the front lights and indicators are now wired up all OK , have all 4 on dipped and main beam
« Reply #33 on: November 15, 2016, 07:40:09 AM »
I believe that lighting regs are min/max 2 dipped, min 2 or max 4 main. Not sure about MOT time.
MIXA
« Reply #34 on: November 15, 2016, 10:33:23 AM »
Thought about this last night havent checked the rules yet but i think you are right
MIXA
« Reply #35 on: November 15, 2016, 11:36:27 PM »
As you said Olds its 2 dipped beam so im putting a switch in hidden away so i can turn the 2 inner off for MOT time
 http://i61.photobucket.com/albums/h59/zuki17/V70%20CUSTOM/91_zpsayyqm0lh.jpg
New build
http://i61.photobucket.com/albums/h59/zuki17/V70%20CUSTOM/90_zps150dpvvo.jpg
New build
The better half won and the air scoop is back on turned around ,just need to put cold air feed from it
 http://i61.photobucket.com/albums/h59/zuki17/V70%20CUSTOM/88_zpsfn18gbgg.jpg
New build
http://i61.photobucket.com/albums/h59/zuki17/V70%20CUSTOM/92_zpsjf00mntj.jpg
New build
« Last Edit: November 16, 2016, 06:04:21 PM by MIXA » Logged
« Reply #36 on: November 16, 2016, 06:14:44 PM »
Grille reminds me of a late model Cadillac or those big Chryslers.  Smiley
MIXA
« Reply #37 on: November 16, 2016, 10:13:55 PM »
First one to get it right the grill is a copy of a caddy/ lincoln
MIXA
« Reply #38 on: November 21, 2016, 10:41:00 PM »
Started on the interior while it rained stopping work on the body , drivers door and tailgate to start
http://i61.photobucket.com/albums/h59/zuki17/V70%20CUSTOM/DSCN0120_zpsfu11js7a.jpg
New build
http://i61.photobucket.com/albums/h59/zuki17/V70%20CUSTOM/DSCN0122_zps3nnjbkgh.jpg
New build
http://i61.photobucket.com/albums/h59/zuki17/V70%20CUSTOM/DSCN0121_zpsh6wuhfi5.jpg
New build
« Reply #39 on: November 21, 2016, 11:08:43 PM »
You're certainly keeping busy!
MIXA
« Reply #40 on: November 21, 2016, 11:18:49 PM »
Trying to Andy hospital in the morning but if its dry out will be doing either the body flatting down or more panels , yours is looking good
« Reply #41 on: November 21, 2016, 11:24:42 PM »
Rain's stopped play here.
MIXA
« Reply #42 on: November 29, 2016, 12:10:04 AM »
All door cards now finished the 1st one had to be redone as the spray glue turned the white cream as it dryed so white double sided tape this time about 45/50 hours work  ,also ordered some leather dye and sealer , next job could be the next on the list plan is to cover it with the white but not sure how i will be doing it yet as its a hard shell have thought of using bars old school style
MIXA
« Reply #43 on: December 02, 2016, 06:32:07 PM »
The leather dye i ordered arrived last night bought 5 lts , i know i dont need that amount but 1 lt was £20.99 5lt was £49.99 so i thought that if i only got the 1 lt i would probably need 1.5 plus 29 quid for 4 lts made it a no brainer , also got a lt of sealer only needs i coat of that , glad realy as its £28 a lt and the price doesnt go down for any additional amount , have to pick up some 1mm sheet on Monday and 2 lenghts of stainless tube 2.5 in dia 60 in long that will be another swift 100 quid for both will add more pics soon .
MIXA
« Reply #44 on: December 04, 2016, 05:03:22 PM »
Made a stupid mistake today , while i have been working on the body work i use cheap pound shop primmer ,  so i finished flatting the bonnet this morning then used Acrylic green stopper  all OK , then used the cheap primmer over it bloody idiot ,yep it reacted good job it still needs wet flatting ,so its 240 wet n dry next then redo the stopper if needed
