December 11, 2025, 11:26:04 PM
General Tech
vw camper t2. servo breather
Topic: vw camper t2. servo breather (Read 3023 times)
dobber
September 29, 2016, 10:37:48 PM »
Hey up all , can anyone enlighten me on the pipe that is tucked up under the front drivers wheel arch in steel [apx 15mm] goes through the inside and appears to join to a flexi pipe and go to the servo for brakes, was slotted on but no way was it tight enough to achieve anything.
does it need to be there or can it go anywhere , been repairs bodged round it so ripped it all off.
cant get photos up. on phone and wont upload.
can i have it in 20 Min's?
Re: vw camper t2. servo breather
September 29, 2016, 10:58:46 PM »
sounds like vac pipe ,,where does the other end go ?
dobber
September 30, 2016, 06:32:59 AM »
hey up mike. been a while.
the steel end, ends with a open rubber gromet end and appears to end between the inner and outer wheel arch. the flexi end is on the servo but was a loose raggy end fit that was not tight enough to seal., servo is right underneath the bus in a very exposed area. cant get photo as all cut off.
September 30, 2016, 12:26:18 PM »
This may help -
http://www.ratwell.com/technical/Microfiche/t205110.gif
dobber
September 30, 2016, 08:35:13 PM »
cheers Archi, will check the flexy bit as it looks like that may be a non return valve in the middle. is there an index where that diagram came from.
