May 06, 2026, 06:51:29 AM *
Pages: 1 2 [3] 4 5 ... 14
Author Topic: Taylor's new project ?  (Read 114108 times)
« Reply #30 on: August 19, 2016, 02:30:44 PM »
Now I've dug it out, it's not the prettiest, the welding is worse than mine (bought off someone on another forum. Yes there are other forums), but would be a good adjuster with a little work. The sprocket has a decent bearing fitted, and is adjustable in height. Just let me know if you want it, or will pass.
http://i915.photobucket.com/albums/ac360/533clive/0BBAD842-C40F-4022-B298-9F0DB5F78009_zpslvkwhnkq.jpg
http://i915.photobucket.com/albums/ac360/533clive/FD4B026F-42BD-4161-9479-06024E6771DC_zpsj2drrtr7.jpg
http://i915.photobucket.com/albums/ac360/533clive/C8250EF6-5007-4145-8435-93B3CE4D53DB_zpsjdcht4il.jpg
« Reply #31 on: August 19, 2016, 06:10:02 PM »
Looks ideal kind sir..please PM me with a price Smiley
« Reply #32 on: August 19, 2016, 06:15:22 PM »
Taylor has been tinkering today..taken one of the ugly side posts out (which was in line of the chain ?) and used it for a central post..
« Reply #33 on: August 20, 2016, 08:44:24 PM »
Thought I'd post some pics of the bike when we first saw it
« Reply #34 on: August 20, 2016, 08:47:27 PM »
Shall try again
« Reply #35 on: August 20, 2016, 09:04:17 PM »
Worked the first time  Wink
« Reply #36 on: August 20, 2016, 09:11:32 PM »
Yes but tiny pics? The resize thing I use keeps changing the settings and I forget which size ? Roll Eyes
« Reply #37 on: August 21, 2016, 09:15:57 AM »
I use 600 x 600.
« Reply #38 on: August 21, 2016, 09:25:33 AM »
Unfortunately it just gives me the percentage size ?  And sometimes it doesn't allow me to reduce it Embarrassed
Rather build stuff than use computers Cool
« Reply #39 on: August 23, 2016, 07:53:14 AM »
Last night was engine mock up time for Taylor ..
« Reply #40 on: August 23, 2016, 12:10:10 PM »
Certainly cracking on with this.
« Reply #41 on: August 23, 2016, 02:40:27 PM »
Actually he's taking his taking time..for once his budget is low for this build Roll Eyes and thanks to Clive for sending the chain adjuster ,cheers dude..
« Reply #42 on: August 25, 2016, 07:16:39 AM »
So the saga continues, the rear sprocket we had on the old wheel didn't match the front sprocket so ended up buying a new rear blank from Mark at powerlinks ( Ringwood ) new tyre has arrived so just some holes to be drilled in the sprocket to enable us to carry on ?
« Reply #43 on: August 28, 2016, 07:01:39 PM »
Wheel has to be welded up ( holes in rim for the old slicks ) so that's at my mates..
So Taylor fitted and welded in a new down tube so we can redo the rear engine mounts ..plus he mounted the front mudguard
« Reply #44 on: September 02, 2016, 06:17:20 PM »
Engine mounts done today
