May 03, 2026, 08:27:11 PM *
Pages: 1 2 [3] 4 5 ... 12
Author Topic: Green-Go (was called Clive's Latest)  (Read 63730 times)
« Reply #30 on: June 25, 2016, 01:36:44 PM »
Also did some trimming of unwanted bits off the swingarm in preparation for having a go at hard tailing it. Some more grinding is required, to remove the last remnants, but I killed my angle grinder, so will be off for a new one tomorrow.
http://i915.photobucket.com/albums/ac360/533clive/DR%20Chop/89226D72-0B1D-441E-9D3B-D86C66319F91_zpsln8mkf07.jpg
« Reply #31 on: June 26, 2016, 01:13:04 PM »
Nothing exciting today, just making the brackets for the 'hardtail', hopefully get them welded on tomorrow morning.
Anyone on here have the ability to put a 180 degree bend (will be about 250mm diameter I think)  in a piece of 20mm tube I have, please?
« Reply #32 on: June 26, 2016, 08:07:46 PM »
My hydraulic bender's at Loony's workshop, but it only puts a bend at a single point, not a continuous curve, unless you move the tube around in the former.
Nathan, (Galaxie500), has a roller bender, which would do it, but only on lightweight tubing, (he uses it for bicycle framework).
« Reply #33 on: June 26, 2016, 08:09:05 PM »
Cheers Andy
« Reply #34 on: June 26, 2016, 08:15:28 PM »
clive  try and find an industrial electrician  ,, a conduit bender should do what you want  Wink Wink
« Reply #35 on: June 27, 2016, 05:40:22 AM »
Is there a particular reason why you are retaining the swingarm, rather than a full bolt in hardtail ?
« Reply #36 on: June 27, 2016, 06:22:39 AM »
Cheers Mike.
No buddy, no particular reason, although, to me, it looks like it creates the right lines but that's just me
« Reply #37 on: June 27, 2016, 06:43:09 AM »
Good enough reason as any. Grin
« Reply #38 on: June 27, 2016, 11:06:55 AM »
Actually, as well as that, it means it takes a lot of guesswork out of some of the other parts of the setup, things that may have been above my knowledge/skill set at the moment; rear wheel alignment, frame making, chain length etc
Managed to get the brackets welded up, and the tubes finished as well:
http://i915.photobucket.com/albums/ac360/533clive/DR%20Chop/DF5ACC1A-CFA5-4614-A5F2-620051CE3B12_zpsr0gapnot.jpg
Still looks a little strange with the seat rails still on, but I don't want to attack them yet, until the seat, and tank arrive................just in case Cheesy
mrhutch
« Reply #39 on: June 27, 2016, 01:04:22 PM »
that looks superb chap..
« Reply #40 on: June 28, 2016, 07:42:42 AM »
Building hardtails around swingarms used to be quite common -as you say Clive, for those with limited facilities, it acts as a built-in jig to ensure everything stays where it should. In the late 80s/early 90s it was popular cos it gave a more purposeful, aggressive look. A lot of big Jap engined chops ran a box section brace through the middle of the hardtail, (where the swingarm would be). I quite like that style.
« Last Edit: June 29, 2016, 05:15:46 PM by Manky Monkey » Logged
« Reply #41 on: June 29, 2016, 04:00:28 PM »
Engine got a bit of a spruce up today. Ignore the gold spark plugs, they were getting changed so we're ideal to leave in to 'plug' the hole (see what I did there? Cheesy Cheesy )
http://i915.photobucket.com/albums/ac360/533clive/DR%20Chop/8DE250C7-81D7-4D89-8854-16AD2D3F59E6_zpsvzvhbpiz.jpg
http://i915.photobucket.com/albums/ac360/533clive/DR%20Chop/C6E67161-A7D6-45F6-A506-B35D42ED10A2_zps8tfk59kq.jpg
Some other little bits and pieces done, but nothing photo-worthy
« Reply #42 on: June 29, 2016, 04:19:09 PM »
That looks tidy, attention to detail I like  Wink
« Reply #43 on: June 29, 2016, 04:20:52 PM »
Thanks buddy
« Reply #44 on: June 29, 2016, 05:18:10 PM »
What did you paint the engine with Clive?
