March 15, 2026, 06:02:03 PM *
Pages: 1 ... 9 10 [11] 12
Author Topic: Scratch built car  (Read 73643 times)
trev
« Reply #150 on: March 26, 2016, 02:15:51 PM »
me too,looking good.
« Reply #151 on: March 26, 2016, 02:20:12 PM »
So am i  Smiley
No Sound
« Reply #152 on: March 30, 2016, 10:33:04 PM »
Cheers all
Spoiler was OK and worked but just too conservative (boring) so I have a new design in my head just need a bit of time on the car. Andy
No Sound
« Reply #153 on: March 31, 2016, 10:19:44 PM »
I made up the rear closing panel which fits behind the rear of the door frame using the same jig I used for the door frame. The gap between the closing panel and the door frame will reduce by 3mm from 8mm to 5mm when the door skin and rear wheel arch panel are folded around the frames. The panel will be welded in when I have all the panels/air inlet in position. Andy
No Sound
« Reply #154 on: March 31, 2016, 10:20:40 PM »
No Sound
« Reply #155 on: March 31, 2016, 10:21:42 PM »
No Sound
« Reply #156 on: April 05, 2016, 10:00:43 PM »
Before I can start the air scoops/wire frame for the rear I needed to make up the sheet metal work for the hatch and the lower panel for the bracket. The retaining pins on the roll bar are angle at 6 degrees from the horizontal so the steel metal work had to match the angle so the hatch can be removed. Andy
No Sound
« Reply #157 on: April 05, 2016, 10:01:29 PM »
No Sound
« Reply #158 on: April 05, 2016, 10:02:15 PM »
« Reply #159 on: April 05, 2016, 10:04:53 PM »
Precision fabrication is a joy to watch -just wish I could do it.
« Reply #160 on: April 06, 2016, 04:20:17 AM »
Lovely work.
Are you using wood formers or do you have access to a pullmax ?
No Sound
« Reply #161 on: April 06, 2016, 10:06:44 PM »
Thanks all
I would love to have a pullmax but I do have a bead roller which helps with strengthening thin sheet.
No Sound
« Reply #162 on: July 23, 2016, 10:44:58 PM »
Sorry for not being around but this will improve over the next month. Anyway the last of the updates until the new work restarts. Cheers Andy
Adjuster/lock for the door plate so I can position the door better and lock the door plate in position (adjustment is made from inside the foot well). The rest of the time has been welding up the rear frame and hatch. I had some old white paint so gave the buck a paint.
No Sound
« Reply #163 on: July 23, 2016, 10:45:42 PM »
mrhutch
« Reply #164 on: July 23, 2016, 11:18:54 PM »
wow
it looks like a CAD render with the white applied
love it
