April 17, 2026, 07:03:54 AM *
Pages: 1 ... 21 22 [23] 24 25 ... 28
Author Topic: Stinkeys trike ?  (Read 143861 times)
« Reply #330 on: August 17, 2018, 07:19:17 AM »
Yes I read about the Antifreeze on Fifers website..does anybody know how he's doing ?
I've got 2 spare gearboxes  Grin so hopefully i will sort it easily,I'm assuming I just unbolt the end piece and go from there ? Sleeved ?
Funny you should mention Harley..I've pinched the M/C off my Chop..which fits perfectly but may need to grind down some of the larger diameter tubing to move it further along?
« Reply #331 on: August 17, 2018, 09:51:08 AM »
Unless the output shaft bearing needs replacing, it's just a matter of unbolting the prop at the gearbox end, then taking off the output flange (big centre nut with lock tab) and carefully lever out the old seal.
There are special thin wall sleeves available that can be pressed onto the flange if it is too worn where the seal rubs.
Not heard from fifer for a while.
If you are changing to a bike master for the front brake, it's possible that you may need a smaller master for the rear.
Lack of brakes after the trike has been standing may be caused by the master cylinder being mounted low down. Residual pressure valves stop this from happening.
« Reply #332 on: August 17, 2018, 03:29:59 PM »
The master cylinder for the rear will hopefully be the same one I've got,I was thinking I may need a residual valve.ive used them before..
« Reply #333 on: September 09, 2018, 06:31:08 AM »
I just wanted say a big THANK YOU to a good buddy and a true GENTLEMAN..who's a fellow Manky..whom I met through this GREAT site..mrs Stinkey and I recently drove over to France to help him decorate his Chateau Grin and has a thank you he bought me something ..which was amazing and certainly not expected ?
Cheers STIX..I'm well chuffed and something to keep me busy..
« Reply #334 on: September 09, 2018, 08:09:19 AM »
Gonna build a chariot? Smiley
Stix
« Reply #335 on: September 09, 2018, 09:36:44 AM »
More than welcome mate only one of the many that have said  “we will come and see you “ that actually did, and I know the financial drain it was, so when you said you needed a trailer for your eventual move it was a no brainier cos I know you wouldn’t accept cash for doing a favour. Enjoy the trailer and getting it modified into what you need.
Stix
« Reply #336 on: September 09, 2018, 09:34:20 PM »
Chariot ? Hmm that's a good idea  Roll Eyes
And your welcome john..I always try to keep my promises.. Cool
« Reply #337 on: September 13, 2018, 06:54:55 AM »
Yesterday I took my trike to a small company that specialises in tuning old classics..( but they don't work on old boys Grin) as recommended by Andy Wink.. Based on the A272 petersfield road not far from Winchester ..
You need to prebook because they can get busy..although he was quite yesterday ..has I turned up an Austin 1100/1300 was pulling out for a test run..it certainly sounded sweet and bought back memories..Tom the Owner likes you to get there early for the ambient temperature ..
We had a break in the weather and managed to unload the trike in between the showers..so while Tom and his son set about tuning it..we had a cuppa and my brother supplied the biscuits ( ginger nuts)
Once he finished..he explained what he'd done..etc..modified the carburettor needle..readjusted the settings,and the timing..better plugs..giving me an extra 12hp  Shocked certainly felt the difference when driving it out of his drive ( uphill) back to the truck..
He told me to just use BP top grade fuel or Esso..and to use the Additive he supplied..he also said this additive would negate Ethanol in any future Fuels?
So needless to say I highly recommend these guys..not cheap but worth it..Aireytuning .com
I wanted to take some pics of the guys working but it was raining.. Embarrassed
« Last Edit: September 13, 2018, 06:58:17 AM by stinkey » Logged
« Reply #338 on: September 13, 2018, 03:17:16 PM »
A 12 horse power gain's pretty good when Reliants only have 40 to start with Smiley
I think they added 12 to mine too. Felt like a completely different vehicle when I rode it home.
« Reply #339 on: September 13, 2018, 08:02:28 PM »
Definitely did..hence the brake system redo...I've put a residual valve into the back brake line and it feels better even without bleeding them..tomorrow I'm running new braided line from handlebar M/C to front caliper..so fingers crossed
« Reply #340 on: September 13, 2018, 09:23:54 PM »
Busy, busy! Smiley
« Reply #341 on: September 14, 2018, 06:18:39 AM »
Well I'm busy trying to find things to do most days tbh Grin been trying to sell the house for 16 months now,viewings have ceased,I believe I won't sell until Brexit sorts itself out ? So stuck in limbo keeping busy
paulywombats
« Reply #342 on: September 14, 2018, 03:27:24 PM »
Well, we learn something new every day....Stinkey's brother has ginger nuts, Stinkey's words not mine.
Living on a wing and a weld
« Reply #343 on: September 14, 2018, 06:09:44 PM »
I was waiting for smutty comments from you lot regarding his gingers? Grin
paulywombats
« Reply #344 on: September 15, 2018, 05:49:29 AM »
Smutty?....how very dare you!. I was referring to his biscuit choice of course, I thought he may have been a Hob Nob Grin Grin
