Got up early today to go breakfast and ride about in a galaxie500 for a bit. I fitted up the top engine mount I got in about 2 seconds flat. Nice kit as it comes with stainless bits and all the holes lined up perfectly. Only downside is I need to trim the fuel tank a bit. Where I put a new tunnel in it the lip on the bottom touches the mount so doesn't sit on the frame anymore.
XS No 3
I also fitted the clutch worm mechanism, which looked terrifying but was real simple once I watched a video on YouTube.
XS No 3
This is where the crossover of parts presents a problem. The clutch cable Andy gave us fits no problem engine side but not into the zxr lever. Not a huge issue, just means may need to get a custom one made.
Then I got excited and decided to mount up the carb kit. The billet mounts are lovely and the rubbers are solid so will support the carbs no problem at all. Once on 2 small issues. I can't get filters on them due to the top rails of the hardtail. Not a major issue as I can get stubby stacks for them. Routing the cables were interesting as it's a 2 - 1. It ended up through the middle of the top mount which may not be ideal. Second issue is that the throttle end is designed for the standard tube on the Xs. I've got a universal one so it doesn't fit. Again not a major issue really.
XS No 3
So left there for a while now while I think about what's next on the list.
XS No 3
