May 06, 2026, 01:34:20 PM *
Pages: 1 ... 4 5 [6] 7
Author Topic: XS No 3  (Read 82819 times)
« Reply #75 on: January 20, 2017, 07:56:27 PM »
Is that the PMA system Archie? Same as Tom's?
« Reply #76 on: January 20, 2017, 08:05:15 PM »
Yeah same as toms. Looks like a nice kit and might buy another one to replace the piranha system on the other bike as all the stuff is nice and small
« Reply #77 on: January 20, 2017, 08:07:25 PM »
That's my back-up plan if the new alternator brushes don't cure my charging problems, so I'll be watching with interest.
« Reply #78 on: January 20, 2017, 10:08:00 PM »
Not too close, might be a while till this goes in
Unless it goes on the other one, but still be a lil while
« Reply #79 on: January 21, 2017, 04:12:49 PM »
Got up early today to go breakfast and ride about in a galaxie500 for a bit. I fitted up the top engine mount I got in about 2 seconds flat. Nice kit as it comes with stainless bits and all the holes lined up perfectly. Only downside is I need to trim the fuel tank a bit. Where I put a new tunnel in it the lip on the bottom touches the mount so doesn't sit on the frame anymore.
http://i257.photobucket.com/albums/hh231/archie837/0AFF544A-B9F2-44A6-818B-BEAF8DA5012B.jpg
XS No 3
I also fitted the clutch worm mechanism, which looked terrifying but was real simple once I watched a video on YouTube.
http://i257.photobucket.com/albums/hh231/archie837/C3122CA5-52FE-4DB8-9A54-A986F9EA93B2.jpg
XS No 3
This is where the crossover of parts presents a problem. The clutch cable Andy gave us fits no problem engine side but not into the zxr lever. Not a huge issue, just means may need to get a custom one made.
Then I got excited and decided to mount up the carb kit. The billet mounts are lovely and the rubbers are solid so will support the carbs no problem at all. Once on 2 small issues. I can't get filters on them due to the top rails of the hardtail. Not a major issue as I can get stubby stacks for them. Routing the cables were interesting as it's a 2 - 1. It ended up through the middle of the top mount which may not be ideal. Second issue is that the throttle end is designed for the standard tube on the Xs. I've got a universal one so it doesn't fit. Again not a major issue really.
http://i257.photobucket.com/albums/hh231/archie837/F98FE25C-F13E-4D74-8A74-9FE7458868D5.jpg
XS No 3
So left there for a while now while I think about what's next on the list.
http://i257.photobucket.com/albums/hh231/archie837/A37ADBC9-F15F-48C6-91AC-1DF4C7229914.jpg
XS No 3
« Reply #80 on: January 21, 2017, 07:58:40 PM »
Carbs look great. My throttle cable runs between the top engine mounts too.
« Reply #81 on: January 21, 2017, 08:59:40 PM »
Oh ok cool. It seemed the only way to get them to run smoothly. Thought the heat might be a problem, but they're in conduit.
« Reply #82 on: April 14, 2018, 08:47:18 PM »
72_BFC2_E7_A36_E_44_EB_9_DD3_6042_B1_FCB26_F" border="0
Cheers for the pipes Andy
Bit of sunshine and managed to get some stuff done. Brakes on the 1100, so that’s ready for mot now
Tank on this looks great in person and rubbish in pictures. Shouldn’t really get carried away with this one and finish t’other xs, but the welders playing up so cant make mounts etc at the moment.
« Reply #83 on: April 14, 2018, 09:05:54 PM »
Smiley My MIG's just sat in one of my lock-ups if you need to borrow one.
« Last Edit: April 14, 2018, 09:07:33 PM by Manky Monkey » Logged
« Reply #84 on: April 15, 2018, 08:28:10 AM »
Cheers mate. I’ve got another one up at mine, just need to pull my finger out and bring it home / get new wire etc. Chances are it’ll be get the 1100 on the road and actually ride something for a bit. Also going to Berlin in 2 weeks so shouldn’t be buying bike stuff really at the moment
« Reply #85 on: April 15, 2018, 08:33:54 AM »
Smiley
« Reply #86 on: December 23, 2018, 10:48:19 PM »
Brought the lift home and got this one on it. Redid the front seat unit with the working welder. Also did some to the nudguard. Rivnutted the frame for its mount. Popped the carbs on as I wanted to try the carb holder to stop them popping off. I also really like the peanut tank, so think I need to get another one for both bikes.
3-FC41344-C7-DC-4-ED3-BA3-E-4-C4-A54655948" border="0
« Reply #87 on: December 23, 2018, 10:49:46 PM »
Carb holder up close
17-F94267-B2-BC-4-E37-8-AFE-929252-BEC9-F1" border="0
« Reply #88 on: December 24, 2018, 03:26:18 PM »
That's nicely made -your work Sir?
My first couple of XSs used to regularly pop & bang & burp their carbs off the rubber manifolds while sat at traffic lights!
« Reply #89 on: December 24, 2018, 07:25:34 PM »
It’s one made by 2 hands motorcycles in Germany. Used to do some nice brackets and stuff, but think he’s shut up shop now
