December 12, 2025, 05:46:16 AM
HotRod Tech
"Old Dorg"
Pages:
39
40
41
42
52
Topic: "Old Dorg" (Read 386468 times)
Re: Rebodied Hotrod
Reply #585 on:
August 13, 2018, 10:07:36 AM »
going to have a look when on holiday in 2 weeks time.
https://youtube.com/user/poprodder
https://www.facebook.com/chrisdralph
I'm on Instagram as @notafoolsvan. Install the app to follow my photos and videos.
https://www.instagram.com/invites/contact/?i=1d8fqu34c7rb6&utm_content=1fsuk8k
Re: Rebodied Hotrod
Reply #586 on:
August 13, 2018, 01:39:16 PM »
How lucky is that
Re: Rebodied Hotrod
Reply #587 on:
August 13, 2018, 07:43:50 PM »
i know!!!! got offered pair of doors and bonnet through another local club member
but these looked like they had been on a banger racer!!!!
Re: Rebodied Hotrod
Reply #588 on:
August 13, 2018, 09:17:05 PM »
"May require some cosmetic work"
Re: Rebodied Hotrod
Reply #589 on:
August 14, 2018, 04:11:45 PM »
i've been trying to use as many frontera parts as possible.
got the steering column roughly in place, this will save a lot of work.
this is roughly stock position on the rover.
length is near enough spot on but does depend on front wing position but there is some movement in wheel position now.
and wheel position, with wheel fitted, i've done this style of car before and i'm going there again!!!!
Re: Down Boy!!!!
Reply #590 on:
August 14, 2018, 05:06:42 PM »
Is that the metal version of a "patchwork" quilt?.........
Re: Down Boy!!!!
Reply #591 on:
August 14, 2018, 05:17:08 PM »
Quote from: morrag on August 14, 2018, 05:06:42 PM
erm yes, and its all going!!!!!
Re: Down Boy!!!!
Reply #592 on:
August 14, 2018, 09:07:56 PM »
So, I hear we're going sky high with this one?
Re: Down Boy!!!!
Reply #593 on:
August 15, 2018, 03:19:29 AM »
Quote from: Manky Monkey on August 14, 2018, 09:07:56 PM
yes!!!!
Re: rebodied hotrod
Reply #594 on:
August 21, 2018, 06:59:11 PM »
box steel ordered, already got steel sheet for floor
floor coming out, new box frame being made up which will also have body mounts to match chassis mount positions,
then new floor.
got to replace brake lines and fuel pipes which will be done once frame work is made.
Re: rebodied hotrod
Reply #595 on:
August 21, 2018, 08:54:19 PM »
Progress! We like progress
Re: rebodied hotrod
Reply #596 on:
August 23, 2018, 09:46:00 AM »
waiting in all morning for a delivery,
wow parcel force can deliver on time!!!!!
i better go get on with it!!!
Re: rebodied hotrod
Reply #597 on:
August 23, 2018, 03:24:14 PM »
Re: rebodied hotrod
Reply #598 on:
August 23, 2018, 04:25:51 PM »
The joys of mock up fab work. Measure ten times, then sit and look, measure another ten times then maybe cut!!!! Lol yes that patch work floor is going, to be replaced by framework and new floor 100mm higher. #channelled #lowslow #ratrod
Patch work floor to be replaced in ratrod. Body was on a car with separate chassis (as it still will be)
the floor is same both sides,
Re: rebodied hotrod
Reply #599 on:
August 28, 2018, 11:26:17 AM »
Slowly building framework up for body channel, same for other side then body will sit 5inches lower on chassis. Floor panels will be last so I can access underneath.
Pages:
39
40
41
42
52
