April 17, 2026, 12:53:38 PM
HotRod Tech
"Old Dorg"
Pages:
42
43
44
45
52
Topic: "Old Dorg" (Read 443962 times)
Re: rebodied hotrod
Reply #630 on:
September 02, 2018, 09:29:21 PM »
Quite a few of us ARE
Re: rebodied hotrod
Reply #631 on:
September 04, 2018, 09:47:35 PM »
little bit of progress today,
rear of floor frame altered to lower body at rear. lots of work, does the job.
started on body mounts, in kit form!!! lol mostly frontera parts.
o/s mounts finished, nothing amazing but will do the job.
got this hell to sort out!!!!
https://youtube.com/user/poprodder
https://www.facebook.com/chrisdralph
I'm on Instagram as @notafoolsvan. Install the app to follow my photos and videos.
https://www.instagram.com/invites/contact/?i=1d8fqu34c7rb6&utm_content=1fsuk8k
Stix
Re: rebodied hotrod
Reply #632 on:
September 05, 2018, 11:07:34 AM »
Holy cr*pthe very best of luck with that birds nest.
Re: rebodied hotrod
Reply #633 on:
September 05, 2018, 12:16:59 PM »
hope to disect the engine loom out of it,
straight forward really as each wire has a plug on the end which will only plug into one place.
Re: rebodied hotrod
Reply #634 on:
September 05, 2018, 05:43:55 PM »
You're flying along Chris! Good progress.
Re: rebodied hotrod
Reply #635 on:
September 05, 2018, 07:14:47 PM »
thanks Andy.
still long way to go.
got the body mounts done on n/s, got to chop out and alter part of front floor frame as its nearly sitting on top of catalytic converter.
started cutting floor panels, amazingly both sides are the same size!!! lol
started mocking up seat, steering pedals etc. notes on pad are dimensions from my daily civic, so should be a comfortable seating position. the seat is only for mock up.
last night i drew out an idea for rear windows, don't know really if i like this, also might have exhaust up the middle.
will need input on this i think.
Re: rebodied hotrod
Reply #636 on:
September 06, 2018, 08:06:50 AM »
Ooh, that'd be loud!
Re: rebodied hotrod
Reply #637 on:
September 06, 2018, 08:15:05 AM »
not really with all existing silencers in place. someone mentioned putting it out the bonnet!!!! thats a no due to noise and having to keep the cat.
Re: rebodied hotrod
Reply #638 on:
September 06, 2018, 05:40:17 PM »
a big ole appeared!!!
to be filled with this.
said item in hole.
problems to sort, but all of that is stock frontera.
Re: rebodied hotrod
Reply #639 on:
September 06, 2018, 06:05:15 PM »
At this rate..soon be done
Re: rebodied hotrod
Reply #640 on:
September 06, 2018, 09:55:15 PM »
Now I'm confused -is that the brake servo or power steering?
Re: rebodied hotrod
Reply #641 on:
September 06, 2018, 10:16:10 PM »
brake servo Andy, thats how its mounted in frontera, tried to keep it as is.
pedal is mounted in black metal part, where rusty bolt is on pic with it on seat.
Re: rebodied hotrod
Reply #642 on:
September 06, 2018, 10:25:12 PM »
Re: rebodied hotrod
Reply #643 on:
September 07, 2018, 05:22:41 AM »
Aah.
Re: rebodied hotrod
Reply #644 on:
September 09, 2018, 11:11:55 PM »
not much done over past few days,
but i've got pedals!!!!
mount for brake servo(part of pedal mount)
and steering wheel!!!
Pages:
42
43
44
45
52
