« Reply #225 on: September 29, 2015, 10:05:29 AM » |
words of advice strip down clean up and free off the 4wd dog in the nose where the front prop fits it will be a job well done as they only rely on a spring to engage the dog when you pull the pin up if it isnt nice and free it wont engage 4wd or only partly engage and chew itself up or jamb in 4wd guess how i know
« Reply #226 on: September 29, 2015, 10:09:34 AM » |
cheers dave and mike. big font of knowledge
« Reply #227 on: September 29, 2015, 05:42:38 PM » |
« Reply #228 on: October 06, 2015, 04:42:10 PM » |
the engine is going back to its orignal position.
makes registering easier(in case of inspection) plus i can buy new propshaft off the shelf for about £60 and it will fit with no messing.
« Reply #229 on: October 06, 2015, 05:04:08 PM » |
Sounds like a sensible move.
« Reply #230 on: October 06, 2015, 05:35:29 PM » |
which prop do you need ,,north lincs clear out will unearth a couple ,,
« Reply #231 on: October 06, 2015, 08:00:22 PM » |
rear mike.
« Reply #232 on: October 08, 2015, 07:57:27 PM » |
back to original plans, engine/box now mounted 5 1/2" forward!!! chassis mounts not altered. onto steering and pedals. blimey space is tight, got steering box bolted onto stock mounts. err........ steering wheel rather close to driver!!! plans to cure that. got a pedal box from a discovery. thats now been chopped into two and now has a big hole drilled between clutch/brake pedals to slide down column. the throttle cable actually fits onto the original mount and fixing on injecter pump which is rather handy!! guess thats a good thing with keeping everything landrover.
no pics yet.
« Reply #233 on: October 08, 2015, 08:51:38 PM » |
Here's a pic for you. Saw this flat roofed pick-up on FaceBook & thought of you.
« Reply #234 on: October 09, 2015, 04:33:48 AM » |
very nice, but why do they always put bling wheels on?
« Reply #235 on: October 09, 2015, 07:19:49 AM » |
because he had them lying about somewhere no doubt ? A posh rat rod ? I wonder if any of them have passed the BIVA test ?
« Reply #236 on: October 09, 2015, 03:14:19 PM » |
been mocking up stuff, got steering box mounted, has caused a few problems as you can see!!! mocked seat up.   as you can see, wheel is a tad too high and in ya face!!!  the only thing in right place is gearstick!!!
« Reply #237 on: October 09, 2015, 05:52:21 PM » |
Easy enough to shorten the steering column?
« Reply #238 on: October 09, 2015, 05:56:59 PM » |
yes, and hopefully keep it looking stock!!
No Sound
« Reply #239 on: October 09, 2015, 09:14:06 PM » |
A bit of foam would be nice on the seats, cracking build. Andy
