« on: May 01, 2015, 07:40:55 PM » |
As per the title, is there anyone on the forum who could make me up a couple of two inch long spacers, pleeeeeease?
Full dimensions to follow some time soon, once my arms work properly
Stix
« Reply #1 on: May 01, 2015, 08:36:32 PM » |
Dimensions and material please and I will see if I have the bits to do them.
Stix
« Reply #2 on: May 01, 2015, 08:45:13 PM » |
Thanks buddy, will get the bits measured in the next day or so hopefully
Stix
« Reply #3 on: May 01, 2015, 09:07:43 PM » |
Ok Stix
« Reply #4 on: May 03, 2015, 05:54:25 PM » |
The good Mr Stix can't do these unfortunately. Anyone else?
I'm after two spacers, 40mm long, outside diameter 35mm, inside diameter 17mm, in steel ideally.
Pleeeease!
« Reply #5 on: May 03, 2015, 08:11:20 PM » |
I will see what materials i have in stock, will get back to you.
« Reply #6 on: May 04, 2015, 05:57:40 AM » |
Sorry, nothing that big diameter wise.
Stix
« Reply #7 on: May 04, 2015, 07:36:17 AM » |
My problem also, could only go to 30mm in alloy. stix
« Reply #8 on: May 04, 2015, 04:51:26 PM » |
Looks like i have some stainless, Are these wheel spacers,Would you like them plain or something a little more pleasing to the eye.
« Reply #9 on: May 04, 2015, 05:35:41 PM » |
They're fork spacers buddy, to go inside, allowing the forks to shorten! So as rough as you like, so long as the inner hole is smooth!
« Reply #10 on: May 04, 2015, 05:46:15 PM » |
Ok.
« Reply #11 on: May 04, 2015, 06:01:51 PM » |
If you can do it, just let me know how much buddy!
« Reply #12 on: May 05, 2015, 05:51:45 PM » |
One down one to go. You had better PM me youre address Clive. Someone better equipped than me Someone better equipped than me
« Reply #13 on: May 05, 2015, 07:07:39 PM » |
« Reply #14 on: May 05, 2015, 08:53:10 PM » |
wow!!! what an amazing group of people on here.
