« Reply #30 on: May 21, 2015, 07:20:54 AM » |
« Reply #31 on: May 21, 2015, 03:32:44 PM » |
A welding and grinding day today!! Got the back all back on. Looks so much cleaner. That little kink in the standard frame supports really annoyed me for some reason. Clive's XL.......errrr, not sure yet!?! Then tried the tank, and then the possible seat hump. All lines up nicely. The seat hump is a little high at the front because of the moulding 'lip'. Clive's XL.......errrr, not sure yet!?! Clive's XL.......errrr, not sure yet!?! Then moved onto re-building the front brake (no pics), and started on an electrics tray to hold the majority of the 'lectrics and battery. Clive's XL.......errrr, not sure yet!?! Battery sits nicely under the hump Clive's XL.......errrr, not sure yet!?!
« Reply #32 on: May 24, 2015, 04:19:23 PM » |
Finished the electrics, just the rear light wiring to complete once the light is here! Clive's XL.......errrr, not sure yet!?!
« Reply #33 on: May 24, 2015, 08:55:13 PM » |
Not hanging around Clive. Nice progress.
hornet6
« Reply #34 on: May 26, 2015, 07:32:20 PM » |
Loving the build and photos. I want to do something similar with that DR 650 motor I,ve got.
no projects ever finished
« Reply #35 on: May 27, 2015, 06:34:52 PM » |
Nothing picture worthy today, but got the front brake master cylinder/handle re-furbished, all the wiring checked, front wheel all cleaned up, and the original paint stripped off the tank.
May have to get another seat unit for it, the one on at the moment is about 6cm too wide at the front, unless anyone has any great ideas for narrowing it? Can you pie-cut fibreglass?
« Last Edit: May 27, 2015, 06:37:50 PM by Clive »
« Reply #36 on: May 28, 2015, 04:23:02 PM » |
Today was tank smoothing and priming day Clive's XL.......errrr, not sure yet!?! The last pic of the tank, until the bikes finished, I'm afraid!!
Stix
« Reply #37 on: May 28, 2015, 04:56:36 PM » |
yup easy to do , just the same as doing it to a steel seat base, cut out the amount you want relieve the back so it plus in and re-glass it. Stix
« Reply #39 on: May 29, 2015, 03:49:05 PM » |
By this weekend, I mean today!! Playing with fibreglass is not something I do very often, so this is probably completely wrong, but seems to have worked so..................yay!!!!!! Cut the required bits out, and pulled it in place with tape: Clive's XL.......errrr, not sure yet!?! After a rough up of the joins, filled the bottom with P38 liberally: Clive's XL.......errrr, not sure yet!?! Once that was set, turned it over and filled the top of the cuts with fibreglass resin: Clive's XL.......errrr, not sure yet!?! After a liberal sanding, and a splash of primer, good as new!! Clive's XL.......errrr, not sure yet!?!
« Last Edit: May 29, 2015, 03:56:21 PM by Clive »
Stix
« Reply #40 on: May 29, 2015, 05:33:34 PM » |
See told you it was easy and no welding required really good job Clive and probably stronger than before Stix
lunatic
« Reply #41 on: May 29, 2015, 05:45:21 PM » |
Had I seen this before that is exactly how I would have said to do it!
« Reply #42 on: May 29, 2015, 07:26:53 PM » |
Cool!!
« Reply #43 on: May 30, 2015, 05:02:39 PM » |
Got this pushed out into the sun today, after fitting the new back wheel, with the same tyre fitted to it. Definitely getting there: Clive's XL.......errrr, not sure yet!?!
« Reply #44 on: May 30, 2015, 06:25:37 PM » |
That's nice Clive. Good to see you today, if only briefly.
