ash
« on: February 13, 2015, 08:06:11 PM » |
hello every one I have acquired a b tyre axle for a Build of mine took the break covers off and I have noticed that one side turnes at normal speed and the other side is very slow when turning shaft. Is this right or is there some think seriously wrong
Cheers bash
« Reply #1 on: February 13, 2015, 08:53:44 PM » |
Try "Googling" differential...............................
« Reply #2 on: February 13, 2015, 09:12:08 PM » |
Do it also rotate the other way
ash
« Reply #3 on: February 13, 2015, 09:41:44 PM » |
I don't think so
« Reply #4 on: February 13, 2015, 10:07:34 PM » |
Chances are that it did  Don't worry about it as long as both sides turn and there are no horrid noises. Lock one side at a time to check all is ok.
« Reply #5 on: February 13, 2015, 10:25:01 PM » |
Also if you have it apart count the number of teeth on the crown and pinion wheels just to make sure its a B type What type of trike you building reliant or bike engine
« Last Edit: February 13, 2015, 11:03:56 PM by terry t »
ash
« Reply #6 on: February 14, 2015, 11:21:10 AM » |
I checked it today and it does rotate the other way. Still slow ill have to strip it all down and try to find whats going on with it. Any one got a maual for stripping. Easy to hard job etc
« Reply #7 on: February 14, 2015, 11:47:34 AM » |
Hi ash. your axle is fine they all do it. it they both turned together in the same direction then you would have problems. what are you putting on reliant or bike engine
« Reply #8 on: February 14, 2015, 12:46:33 PM » |
Terry is correct. The fact that one side rotates the other way, or at a different speed really is not a problem. If they rotated the same way and at the same speed it would mean you had a welded or locked diff.
ash
« Reply #9 on: February 14, 2015, 04:30:08 PM » |
I'm waiting on a hard tail frame. Would of liked a v twin as the donor engine but frame is made for an tea pot engine. Brought the axle on a whim say b on the stamp.can get pic
« Reply #10 on: February 14, 2015, 04:39:19 PM » |
No that's fine we all know what a reliant axle looks like. it just there were some out there sold as B type but are infact A 3.23
« Reply #11 on: February 14, 2015, 06:44:04 PM » |
"tea pot engine"?
ash
« Reply #12 on: February 14, 2015, 06:49:43 PM » |
Air oil cooled engine. Bandit gsxr
« Reply #13 on: February 14, 2015, 06:55:12 PM » |
Ahh, right-o.
« Reply #14 on: February 14, 2015, 09:43:45 PM » |
If you use that tea pot engine check drive rotation as you may have to turn the axle over
