I reckon you'll find you'll be pushing that pedal a lot harder than with drums, but I would go with the mc you have until you try it.
Discs work well in terms of fading, snatching, etc, but there's a reason they all have servos.
Let us know eh?
Huw
Indeed, the reason is that they normally need a larger bore m/c to supply enough volume but the bigger bore means at reduced line pressure hence servo on 4 wheel system. However racing systems use tandem m/cs ( 2 side by side ) so you get the volume AND pressure without need for servo . They feel strange to start with , especially when you are used to servo brakes but work great. On a trike with a separate rear system you are effectively using that system.
