April 29, 2024, 05:51:31 AM *
Author Topic: New MSVA Manual  (Read 1684 times)
« on: December 16, 2014, 08:49:09 PM »
Posteds by a vehicle examiner on another forum......
A new MSVA manual has been published on the dot gov website.
I've only had a quick read but it seems little has changed apart from some lighting regs. Rear position lamps (tail lights) the maximum height has gone up to 1500 mm.
« Reply #1 on: December 16, 2014, 10:10:08 PM »
Will have a check through tomorrow. But I doubt that I will be doing another trike or bike for at least 4 years.
« Last Edit: December 16, 2014, 10:13:01 PM by Olds » Logged
« Reply #2 on: December 17, 2014, 07:32:15 AM »
Had a look through. It's mostly adding notes.
Section 2 Mirrors Un bodied vehicles. Time constrained element removed (whatever that was )
Section 4 Speedometers. Note saying GPS not a suitable substitute.
Section 6 Lighting.  3 wheeled mopeds rear lights max height corrected to 1500mm
Section 8 External Projections - Un bodied. Ball end levers may have a flat or be hollow on the bottom of the ball.
                                             Bodied.  Slight wording change re-hub centres/hub caps.
Section !5 Tyres. Note added re- DOT marking only acceptable if weight and speed ratings are also present.
Think that's it. But if you are building for MSVA, download the latest version and read it yourself.  Smiley
« Last Edit: December 17, 2014, 07:50:31 AM by Olds » Logged
