April 25, 2026, 06:21:50 AM
Trike Tech
Axle Shortening Pros & Cons
Pages:
Topic: Axle Shortening Pros & Cons (Read 8162 times)
Re: Axle Shortening Pros & Cons
Reply #15 on:
August 21, 2014, 08:33:06 PM »
I drilled the rivets out pressed out the axle tube. cut to size machined the end and pressed it back in. as for the shaft I done the same as morrag but I sleeved welded and pluged mine
Heres a photo of the my trike
paulywombats
Reply #16 on:
August 21, 2014, 08:48:34 PM »
Lovely job, looks like it came out the Honda factory like that.
Living on a wing and a weld
paulywombats
Reply #17 on:
August 25, 2014, 03:26:09 PM »
What overall width did you go with?
Cheers
Paul
Reply #18 on:
August 25, 2014, 03:49:23 PM »
Quote from: paulywombats on August 25, 2014, 03:26:09 PM
Cheers
Paul
Hi Paul. he overall width is 1270mm including 50mm (25mm each side) 4" to 100mm wheel adaptors. when I looked at building this the one thing that I wanted was to keep it compacted but also to look good. I think I have achieved that just need to come up with a colour that will suit it. then ask Marcus to spray it
Pages:
