April 25, 2026, 02:51:24 AM *
Author Topic: prop rubber buffer  (Read 5871 times)
digger06
« on: August 18, 2014, 01:28:49 PM »
dont have a prop on my trike, just a u/j,
whilst it doesnt pose a problem, i was thinking of swapping it out
in favour of a rubber buffer style thingy,
i have seen these on some of the newer rear wheel drive propshafts on cars,
anyone had experiance with these? or had any ideas on which to try and use,?
« Reply #1 on: August 18, 2014, 03:42:54 PM »
Think most BMW cars now have them, bit like the old Hillman Imp rubber doughnut, Lotus had them on the elans and I think Triumph used them on GT6 and spitfire variants. Do recall many moons back some bad press and many tried to convert to a constant velocity type joint, but things have moved forward in rubber gear now.
« Reply #2 on: August 19, 2014, 05:29:54 PM »
I made up the carriers for one once ( for a chèvre tote rally car), it took quite a bit of machining. If you can get one to bolt on, laughing, otherwise it could be expensive.
Huw
« Reply #3 on: August 19, 2014, 08:11:11 PM »
Ford Granada?
saex69
« Reply #4 on: August 19, 2014, 11:57:47 PM »
I'm thinking of doing the same digger06 as i to don't have a prop and the way i see is my engine is fixed as is the axle so using a doughnut as a cushdrive would work the same as on a motor cycle, the one i'm using is from a BMW.
digger06
« Reply #5 on: August 23, 2014, 08:39:47 AM »
you got any pics of this?
saex69
« Reply #6 on: August 23, 2014, 03:53:31 PM »
Here ya go you will only need to use 4 holes or you could use all of them.
« Reply #7 on: August 24, 2014, 11:19:04 AM »
3 each surely?
Huw
« Reply #8 on: August 24, 2014, 11:27:13 AM »
Three for the input shaft,And three for the output shaft,
digger06
« Reply #9 on: August 24, 2014, 01:32:42 PM »
is that capable of taking a bit of movement/misalignment, or is it just for shock absorption?
« Reply #10 on: August 24, 2014, 01:43:18 PM »
It's basicaly a shock absorber,
But you can trasmit a couple of hundred horspower through these things.
This one's from a BMW Z4 i think.
http://i290.photobucket.com/albums/ll259/spares_photos/IMAG0044_zps51b55151.jpg
prop rubber buffer
« Reply #11 on: August 24, 2014, 05:18:51 PM »
Would have thought these would be better than a single UJ on a Reliant where there is no sliding coupling. It would allow for the linear expansion you get as the gearbox and diff heat up.
digger06
« Reply #12 on: August 25, 2014, 07:23:07 AM »
what about a cv joint?as above, it was the heat/expansion i was thinking about,
« Last Edit: August 25, 2014, 07:25:08 AM by digger06 » Logged
phunkie hiboy
« Reply #13 on: August 25, 2014, 08:57:43 AM »
Modern marine/boat drive shaft systems use CV joints now, we have one fabricated in this style for our inboard engined speed boat. If you use this type of shaft, the ends it's attached to (gearbox and rear axle) have to be solidly mounted at either end i.e. normal style gearbox with a bolt on flange and something like a Sierra rear axle. Basicly you'd be using front wheel drive shaft technology
http://www.aquadriveusa.com/system/system.htm
« Last Edit: August 25, 2014, 09:13:57 AM by phunkie hiboy » Logged
« Reply #14 on: August 25, 2014, 09:04:44 AM »
Plus they are a bit bulky
