April 18, 2026, 01:45:48 AM *
Pages: 1 ... 57 58 [59] 60 61 ... 89
Author Topic: New Olds (boat tail speedster)  (Read 588301 times)
« Reply #870 on: January 23, 2016, 08:29:02 PM »
Nicely done Sir.
Mendalot
« Reply #871 on: January 23, 2016, 09:21:55 PM »
Bet that gave you a lot of satisfaction Cheesy   have you had it on your truing machine yet?
« Reply #872 on: January 23, 2016, 09:52:23 PM »
Yep and yep.  Grin
 I nearly have it running true. About 1mm up and down and 2mm side to side run out at the moment which should be ok but think I can get it better than that.
Been a lot of work just for some wheels but I really want wires on this and can't justify the cost of having them built by someone else.
« Last Edit: January 24, 2016, 08:23:35 AM by Olds » Logged
« Reply #873 on: January 26, 2016, 04:39:48 PM »
some new rims for you:
« Reply #874 on: January 26, 2016, 05:16:22 PM »
« Reply #875 on: January 26, 2016, 05:17:22 PM »
Yep and yep.  Grin
looks great dave, but your a braver man than me in the kitchen!!!!!!
« Reply #876 on: January 26, 2016, 06:35:01 PM »
That's nothing ! Mind you, the wife was in Japan at the time. Cheesy
« Reply #877 on: January 26, 2016, 07:46:37 PM »
Right, get rid of one of the chairs, you don't need 2! mount it on one lower corner on a small motor driven turn table, with a spot light above, instant "Pop-Art", or what? Cheesy Cheesy Cheesy Cheesy, and then all you have to do is explain your reasoning to the Divorce lawyer......... Huh Huh Huh Huh..Morrag
« Reply #878 on: January 26, 2016, 09:39:40 PM »
No.No.No.No.
Flip it over get a nice piece of glass on it,
Lovely coffee table.
« Reply #879 on: January 26, 2016, 11:20:06 PM »
 Grin Grin Grin
Luckily I have a very understanding wife. She must be, as we've known each other for forty seven years and been married for thirty nine.
« Reply #880 on: January 30, 2016, 09:01:36 PM »
Fancied doing a bit of metal spinning and as I dislike the std. hubcaps (plus they are bloody expensive) thought this would be a good little weekend task.
Mendalot
« Reply #881 on: January 30, 2016, 09:23:19 PM »
« Reply #882 on: January 30, 2016, 09:51:59 PM »
Damn you & your metal sorcery! -or should that be saucery Smiley
Love the colour, but I still don't quite understand how metal spinning's done -sheet of ali attached to the lathe chuck with a bolt with a wooden mold behind it & you just push it over the wooden buck with a hammer handle or similar? Do you have to heat the metal as you do it? I'd love to see it done.
« Reply #883 on: January 31, 2016, 07:45:39 AM »
It's really quite easy with practice. The sheet is held against the form using the tailstock with running centre, with a spacer, (no bolt) and is slowly worked into shape while it's spinning, using a polished or rotating tool mounted on a long handle. Lots of vids on the internet. I watched a few (ok,more than a few) before trying it.  Cheesy
The wheel colour is the etch primer. Been pondering the colour. Could go safe with black, or whatever the final body colour will be (still not sure- dark green or maroon) but have decided that I want the wheels to stand out visually.  So they will be Old English White. Just so happens that I have a few litres of cellulose in this colour left over from the MG.
Pic shows my spinning setup. Toolpost has been replaced with a tool rest (spanner and socket, Smiley ought to make a proper one) and tool is a length of tube with a polished brass tip. While actually spinning the work, it's covered in grease to prevent galling. May try to make a rotating tool to get a better finish and it should make spinning easier.
« Last Edit: January 31, 2016, 09:03:02 AM by Olds » Logged
« Reply #884 on: January 31, 2016, 10:09:42 AM »
You make it look so easy!
