April 29, 2024, 12:09:23 AM *
Pages: 1 ... 35 36 [37] 38 39 ... 89
Author Topic: New Olds (boat tail speedster)  (Read 399664 times)
« Reply #540 on: June 25, 2015, 08:58:24 PM »
Damn, is there nothing you can't make Dave?!
« Reply #541 on: June 25, 2015, 09:05:39 PM »
cakes?
« Reply #542 on: June 25, 2015, 09:17:14 PM »
My chocolate sponge cake is to die for. Grin
Mendalot
« Reply #543 on: June 25, 2015, 09:29:25 PM »
Send some up to Hertfordshire then  Tongue Tongue
« Reply #544 on: June 26, 2015, 03:18:43 PM »
One done one to do. But I think I've made the overall diameter too big and it might cause problems with the bonnet.  Undecided
« Reply #545 on: June 26, 2015, 04:56:12 PM »
Oh shut up  Smiley , I'm sure you will sort it out
« Reply #546 on: June 27, 2015, 07:28:20 AM »
Cry
 Too big! Started again.  The bottom edge will still be a bit close to the bottom of the air intake bulge but should clear.
« Last Edit: June 27, 2015, 02:32:22 PM by Olds » Logged
« Reply #547 on: June 27, 2015, 04:15:03 PM »
See, you did sort it Smiley
« Reply #548 on: June 27, 2015, 05:01:20 PM »
Yep  Grin Took most of the day though. Should have thought it through to start off with.  Roll Eyes
« Last Edit: June 27, 2015, 05:05:05 PM by Olds » Logged
« Reply #549 on: July 02, 2015, 08:15:34 AM »
The steel arrived for the rear firewall yesterday and I was making good progress until I ran out of welding wire.
Might have looked better if the dimples were graduated, but that would have meant making three sizes of formers.
« Last Edit: July 02, 2015, 10:51:11 PM by Olds » Logged
« Reply #550 on: July 02, 2015, 12:37:49 PM »
Tea bags from now on then!
I'm curious how you attached the flanges to the sum tubes?
« Reply #551 on: July 02, 2015, 02:35:23 PM »
I assume you mean the SU ram tubes.
The flange bores were chamfered each side.  One to match the tube taper and the other  side a 45 deg. x 3mm and the tube end was swaged into this chamfer.
« Last Edit: July 02, 2015, 02:47:39 PM by Olds » Logged
« Reply #552 on: July 05, 2015, 10:44:16 PM »
Started stripping down the body so that I can finish some welding and paint the body frame and thought I'd see how much things weighed.
The steel rear section (boat tail) is a bit heavy at 16kg but the alloy body panels only total 5kg and the bonnet and front sections another 8kg.
Don't know what the body frame weighs, but taking axle weights with everything fitted so far and allowing for fuel, battery and all the bits still to be fitted, I think the vehicle should weigh roughly 1188 lbs. (540 kg). A Morris 8 = 1738 lbs.  So should be 550 lbs. lighter Grin
« Reply #553 on: July 05, 2015, 10:54:22 PM »
Wow!
« Reply #554 on: July 06, 2015, 09:02:04 AM »
Best bit is, combined with the engine change, the power goes from 39 to about 111 BHP/Ton. Not massive, but a decent improvement. Grin
« Last Edit: July 06, 2015, 09:31:36 AM by Olds » Logged
