April 28, 2024, 10:19:40 AM *
Pages: 1 ... 19 20 [21] 22 23 ... 89
Author Topic: New Olds (boat tail speedster)  (Read 399565 times)
« Reply #300 on: January 10, 2015, 10:16:57 PM »
You know we all hate you don't you Dave.  Tongue
He may be annoyingly talented, but he smells funny & throws like a girl.  Shocked
« Reply #301 on: January 10, 2015, 11:43:01 PM »
What i want to know is how does he drill them square holes.
All the drill bits i have are round.
« Reply #302 on: January 11, 2015, 08:00:47 AM »
You were told not to tease. Cry I'm gonna tell your mum !  Tongue
Silly boy ! You grind round drill bits, to make them square.  Roll Eyes
« Last Edit: January 11, 2015, 08:05:49 AM by Olds » Logged
phunkie hiboy
« Reply #303 on: January 11, 2015, 09:05:02 AM »
You just have to have the right tools!!
https://www.youtube.com/watch?v=rjckF0-VeGI
« Reply #304 on: January 11, 2015, 11:36:01 AM »
Nice bit of kit.
If you don't have a few grand to spend, there is this version. A bit old school but it works.
« Reply #305 on: January 11, 2015, 12:15:40 PM »
I spent months when I was a young apprentice learning how to file and chisel correctly, had bruised and skinned hands from holding that damn chisel, still miss sometimes but I'm learning.
« Reply #306 on: January 13, 2015, 07:28:51 PM »
Never stop learning. Smiley
Carbs have arrived. Twin 1 1/4" HS2 and MG 1100 manifold. Had a slight problem with a broken dashpot screw. It had sheared off flush with the surface and would not budge. A lump of weld on the end (something to grip onto plus adds heat) then a soak in WD40 and it came out cleanly.
They will obviously need a refurb, but it's a nice little job I can do inside in the warm, when it gets cold in the garage.
« Last Edit: January 13, 2015, 07:32:42 PM by Olds » Logged
« Reply #307 on: January 13, 2015, 07:47:49 PM »
I'm not causing trouble, but try the dishwasher. Wink
« Reply #308 on: January 13, 2015, 11:17:34 PM »
Are you joking, or do you mean it
« Reply #309 on: January 13, 2015, 11:27:22 PM »
I've washed cylinder heads and allsorts in mine.
But don't tell the swimbo.
« Reply #310 on: January 14, 2015, 11:36:22 AM »
After an hour soaking in very hot water and dishwasher powder and a little scrub with an old tooth brush.
Cheaper than sending it off for vapour blasting !
« Reply #311 on: January 14, 2015, 12:46:58 PM »
Thats impressive, I'll send mine up Grin
« Reply #312 on: January 17, 2015, 04:58:32 PM »
The twin carbs have really changed the look of the engine. Rebuild not finished, but now they are temporarily mounted, I can make a start on the exhaust manifold. Looks like I will have to make do with short ram pipes, as the mouth of the front carb, already protrudes past what will be the bonnet side line.
« Last Edit: January 17, 2015, 05:01:09 PM by Olds » Logged
« Reply #313 on: January 17, 2015, 05:10:42 PM »
That does look rather spiffing Dave.
« Reply #314 on: January 18, 2015, 09:20:31 AM »
i concur
